turbo carb size - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2007, 12:44 PM
turbo carb size
when running a turbo what size carb should i use?
Old 03-12-2007, 02:27 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
We need a little more info than that. Like: what size engine, heads, cam, turbo size, max rpm, and power level.
Old 03-12-2007, 02:30 PM
Drewnashty's Avatar
sitis nam accelero
I'm not one to answer your question but I do know they are gonna need info regarding your engine, desired power, RPM range, use of vehicle...
Old 03-12-2007, 04:32 PM
Wiki Edits: 31
there's an actual way you impliment the boost preassure in as a decimal, after you find your base CFM that there are many calculators on the net for. I think you multiply it in as a decimal, but I'm not shure. www.performancecarburators.com can make you any carb you want tho, they can help you figure the CFM out also
Old 03-12-2007, 08:02 PM
its a sbc 350
its got vortec heads
stock cam
stock turbo off a powerstroke diesel
about 300hp
Old 03-12-2007, 08:06 PM
you can easily make 300hp without a turbo for much less headache with a sbc.
Jerome
Old 03-12-2007, 08:14 PM
1969NovaSS's Avatar
You do not need a turbo for 300hp. With the vortech heads and decent cam and intake you can make it. What year powerstroke? '03 and up are variable vane and are computer controled and wont work on your car. If it is off of the 7.3 I think it may be too big for your car. Since you only want 300 and still want a turbo I figure your looking for a turbo that will spool imediately. That trubo will probably start to boost at 3000rpm or later.
Old 03-12-2007, 08:46 PM
no i meant it'll have 300hp before a turbo
http://users.erols.com/srweiss/calchpb.htm
i found that website from this site
it calculates how much power is given when you tell how much boost and how much power before the turbo
and at 300hp id probably run between 5-8lbs of boost
im gunna get a boost controller so i can control how much boost
Old 03-12-2007, 09:26 PM
how much horse power and torque can stock sbc350 internals handle?
Old 03-12-2007, 09:44 PM
my alter ego
That calculator is not accurate. There is no way that the baseline figures he listed will make that HP....too much energy lost in heat and friction to ever come close to 100% efficiency....try another from somewhere else.
Old 03-12-2007, 10:26 PM
techinspector1's Avatar
Wiki Edits: 326
I've always used the formula given by Blower Drive Service to determine CFM required, whether it be a blower or turbo, they both compress air. The formula is a little tricky until you use it a few times and get used to it.
(CID X RPM divided by 3456) X (BOOST divided by 14.7 + 1)
You have to treat this as two calculations. Take a 350 Chevy turning 6,000 and stuffing 8 lbs into it for example:
350 times 6,000 divided by 3456 = 607 CFM
8 divided by 14.7 = .54
Add a 1 in front of the .54 to reach 1.54
Multiply 1.54 times 607 and find that the cfm required will be 934 CFM.
Hope this helps.
Old 03-13-2007, 08:52 AM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
go out and buy : TURBOCHARGERS by Hugh Maclnness, HP Books-49, ISBN 0-89586-135-6 everything you should know BEFORE you start is in that book, take your time to read it, it's worth it, I'm telling you amigo.
Augusto.
Old 03-13-2007, 10:13 AM
Buick Hybrid Guy.
Carbs are never ideal for boosted applications on a street driven vehicle. I don't care how many jets or bleeders you put in it a carb just can't be adjusted for the perfect AFR like injection.
A carb will work. No doubt there but don't plan on getting 20mpg or not having flat spots or rich spots in the fuel curve.
You can tune a carb to WOT with out much trouble and make close to the same HP as injection. It's everything in-between that's the problem.
With that being said... I'd recomend a turbo in the .62 to 66mm range Low .70's if you plan on making more power. That will support 600-700 hp. I'd use a GN style turbo as they are easy to find and not very expensive. You'd need a .85 A/R exhaust housing (3bolt or 4bolt) 4bolt flows a bit better.
You can pick a used GN turbo off turbobuick.com for around 3-600.00
You'll need a boost ready carb from Performance carbs (link in above post) or similar. A hat for the carb and alot of exhaust/intake/intercooling fabrication.
Everything I own is Turbocharged. You'll make over 500hp to the wheels with out much trouble and it won't be hurting the bottom end.
Tuning is going to be critical. You'll need a Wide band O2 to get that process started. And a lesson in tuning if your not sure where to be at.
Boost will be dependant on detonation and what fuel you run.
It'll be awsome when finished.. don't give up or be intimadated by the work. It will all pay off when it's setup right.
Good luck!!!
Scott~
Old 03-13-2007, 11:52 AM
^ ill have to get that book how much is it anyway?
Old 03-13-2007, 12:54 PM
Buick Hybrid Guy.
books.
Here's a link from amazon.com for
http://www.amazon.com/s/ref=nb_ss_gw...Go.x=12&Go.y=3
There was used for 4.00 somthing and new for 17.00.
That is a older turbocharging book but all the basics are there and it's a good start to understanding what's needed.
~Scott
SBC twin turbo - motor size & specs? stratt134 Engine 10 07-26-2006 01:29 PM
what size carb do I have? henkelphoto Engine 3 02-13-2006 03:41 AM
carb size for this setup (street) joeyg329 Engine 4 01-28-2004 09:03 AM
Cam Size / Carb Selection Relationship, Four Corner Idle rmhuizenga Engine 9 06-20-2003 08:54 AM
Which size Holley Carb bigjoedo Engine 34 01-06-2003 03:12 PM
