-   -   Turbo Chargeing 305 (http://www.hotrodders.com/forum/turbo-chargeing-305-a-191008.html)
SUPERDAVE0454 01-19-2011 05:48 AM
Turbo Chargeing 305
Have Cast Crank 500 Hp Rods Hyperutective Pistons How Much Boost Can I Run
345 desoto 01-19-2011 08:27 AM
Keep increasing the boost until the engine blows, then back off 5 lbs. Sorry, I couldn't resist... :welcome:
bondo 01-19-2011 09:03 AM
Ayuh,... And the compression ratio Is,..??..??
cobalt327 01-19-2011 09:17 AM
WTH are "500 HP rods"?
There are far too many unknown parts to your question- the exact set-up needs to be laid out.
Anyway, 5 psi will be too much if the tune is off, 10+ psi could be conceivably done if things were exactly spot-on.
IMO, if you are serious about running boost- use the right parts from the beginning. That way there's a bit of a safety margin when (not IF) things go wrong.
LATECH 01-19-2011 06:58 PM
turbocharging with cast cranks and hyper pistons dont mix well. Youll need forged internals if your gonna get serious.
Also most turbo engines run a dished piston to lower compression as turbo charging will definetly increase the compression when active in boost mode. Dished pistons are also helpful to keep the combustion chamber a little cooler to help with detonation.
Oh did I mention that sodium filled valves are a good Idea so they dont seize in the head after you dog the turbo on the expressway. :P
LATECH 01-19-2011 07:02 PM
Oh yeah, the cost of a turbo and all the plumbing to run it and an intercooler
orangejuiced86 01-19-2011 08:18 PM
"Boost" is all relative to air flow. The air flow that CANT get in is your boost reference. If your top end is efficient and flows air well you will see MORE power with less boost. What heads/cam/intake are you running, What are the specs on the heads. LOTS of things come into play when talking "boost"
Basically you should be focused on a safe horsepower amount with your engine.
You can take 2 cars and compare and see that one makes 800hp registering 10lbs of boost, and the other makes 500 registering 19lbs of boost.
Torque454 01-19-2011 10:33 PM
Finding any good 305 pistons will probably be a challenge. Not many people build 305's.
I'd probably stroke it to a 331 and then boost it. I did play with a 305 once a while back. I also entered a bunch of info into comp cams camquest software (like desktop dyno), entering crazy stuff like 30psi boost with a big turbo (just picked one out of the list) and entered whatever valve sizes and all required info..
Came up with like 900hp lol But the mods to get that would be expensive.
BigRoy1978 01-20-2011 12:27 AM
Oh really? no one builds 305's?
there is a whole sprint car world out there that runs 305 chevys...with the stock bore and stroke, most even run the stock length rod. all forged stuff!!
look at speedway motors and day motorsports, under the sprint car section.
Torque454 01-20-2011 06:38 PM
When did I ever say "no one". I said "not many" You may know of alot of people that build them, but in the big picture there aren't that many. Its cheaper to build a 350, 383 or 400 and have better results.
Because of this, there is not much demand for parts. I'm sure if you look hard enough you might find some, but I dont know.
I dont find many parts for a turbocharged gas V8 of any type, let alone a small block or even worse, a 305.
BigRoy1978 01-20-2011 06:42 PM
it would be a lot cheaper to build a HOT 383, than a turbo 305 that has less power, and is a lot more upkeep!
but, some people just dont see it that way.
zildjian4life218 01-21-2011 08:34 AM
http://www.hotrodders.com/forum/jour...99&action=view
