Turbo Chargeing 305 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2011, 04:48 AM
Turbo Chargeing 305
Have Cast Crank 500 Hp Rods Hyperutective Pistons How Much Boost Can I Run
Old 01-19-2011, 07:27 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
Keep increasing the boost until the engine blows, then back off 5 lbs. Sorry, I couldn't resist...
Old 01-19-2011, 08:03 AM
bondo's Avatar
Ayuh,... And the compression ratio Is,..??..??
Old 01-19-2011, 08:17 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
WTH are "500 HP rods"?
There are far too many unknown parts to your question- the exact set-up needs to be laid out.
Anyway, 5 psi will be too much if the tune is off, 10+ psi could be conceivably done if things were exactly spot-on.
IMO, if you are serious about running boost- use the right parts from the beginning. That way there's a bit of a safety margin when (not IF) things go wrong.
Old 01-19-2011, 05:58 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
turbocharging with cast cranks and hyper pistons dont mix well. Youll need forged internals if your gonna get serious.
Also most turbo engines run a dished piston to lower compression as turbo charging will definetly increase the compression when active in boost mode. Dished pistons are also helpful to keep the combustion chamber a little cooler to help with detonation.
Oh did I mention that sodium filled valves are a good Idea so they dont seize in the head after you dog the turbo on the expressway.
Old 01-19-2011, 06:02 PM
LATECH's Avatar
Oh yeah, the cost of a turbo and all the plumbing to run it and an intercooler
Old 01-19-2011, 07:18 PM
"Boost" is all relative to air flow. The air flow that CANT get in is your boost reference. If your top end is efficient and flows air well you will see MORE power with less boost. What heads/cam/intake are you running, What are the specs on the heads. LOTS of things come into play when talking "boost"
Basically you should be focused on a safe horsepower amount with your engine.
You can take 2 cars and compare and see that one makes 800hp registering 10lbs of boost, and the other makes 500 registering 19lbs of boost.
Old 01-19-2011, 09:33 PM
Finding any good 305 pistons will probably be a challenge. Not many people build 305's.
I'd probably stroke it to a 331 and then boost it. I did play with a 305 once a while back. I also entered a bunch of info into comp cams camquest software (like desktop dyno), entering crazy stuff like 30psi boost with a big turbo (just picked one out of the list) and entered whatever valve sizes and all required info..
Came up with like 900hp lol But the mods to get that would be expensive.
Old 01-19-2011, 11:27 PM
BigRoy1978's Avatar
Oh really? no one builds 305's?
there is a whole sprint car world out there that runs 305 chevys...with the stock bore and stroke, most even run the stock length rod. all forged stuff!!
look at speedway motors and day motorsports, under the sprint car section.
Old 01-20-2011, 05:38 PM
When did I ever say "no one". I said "not many" You may know of alot of people that build them, but in the big picture there aren't that many. Its cheaper to build a 350, 383 or 400 and have better results.
Because of this, there is not much demand for parts. I'm sure if you look hard enough you might find some, but I dont know.
I dont find many parts for a turbocharged gas V8 of any type, let alone a small block or even worse, a 305.
Old 01-20-2011, 05:42 PM
BigRoy1978's Avatar
it would be a lot cheaper to build a HOT 383, than a turbo 305 that has less power, and is a lot more upkeep!
but, some people just dont see it that way.
Old 01-21-2011, 07:34 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
http://www.hotrodders.com/forum/jour...99&action=view
Thrush Turbo or Dynomax Super Turbo? henkelphoto Engine 3 08-24-2006 11:46 PM
non turbo to turbo eclipse Dainleljedal06 Engine 1 07-31-2006 10:13 AM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 12:35 PM
Super Chargeing an engine???? neil madsen Engine 3 10-28-2002 01:29 PM
