Turbo-flite - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2007, 02:23 PM
I am looking for a drive spider for the turbo flite by hydro-motive, I know they are hard to find but am looking to get lucky!!
Any help, please let me know.
Old 02-09-2007, 02:29 PM
Turbo-flite
I know this will be hard to find however I am looking for a drive spider for a turbo-flite (clutch-turbo) made by either B&M or Hydro-motive.
Thanks
Old 02-09-2007, 02:49 PM
R4MM's Avatar
GUILLOTINE
hmm is it the one with....
is it the one with 4 pins on the side of the clutch? because im trying to find out wich one i have
Old 02-09-2007, 03:06 PM
I am not sure what you are talking about on the clutch, mabey give me some more detail. My automatic trans guy, worked for hydro-motive in chicago and is well versed in these transmissions, so we can possibly help. What I need is the three forked device that sits next to the throw out on the shaft, and then they are held in place with a snap ring.
Old 02-09-2007, 03:48 PM
R4MM's Avatar
GUILLOTINE
2 way
ok thats not what i have and i also dont have what you have but the thing i have has an ordinary atick shift with 4 pins running from the bottem of it to the head wich says 12345R (the gears) any ideas becasue i need to know what it would do if i stuck it in my truck and if i could sell... ill look for that clutch you wanted throuigh every ones posts to help you.
Old 02-09-2007, 10:41 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Seems like the units were called "clutch flight" or something similar.
then there were the "clutch turbos"
Old 02-10-2007, 04:51 PM
BOBCRMAN@aol.com's Avatar
Haven't seen one in many years but the clutch turbo's were also built by Fairbanks. I ran one back in the day "poor mans Lenco" The drive spider on mine was a brass/bronze colored casting.
Old 02-10-2007, 05:03 PM
I know a guy locally who has these and makes parts for them.
The only way to get in touch is by phone and you will probably have to leave a message. Call Ken at US Speed: 414-550-2429 or 414-762-7823. Good luck, this is the man in the know....
Looking at the remote mount turbo will my vortec heads get the job done leemoses Engine 14 10-06-2010 07:51 AM
Turbo 350 & 550 HP BB Chevy leejoy Transmission - Rearend 4 12-06-2007 10:56 PM
modifying a fwd cars strut tower for turbo clearnce - advice needed lowROLLERchevy General Rodding Tech 4 03-11-2006 12:20 AM
pontiac 301 turbo gutted 87442lover Engine 10 04-30-2004 08:27 PM
Backpressure = Bad.... Right?? D M N Engine 20 01-02-2004 05:53 PM
