turbo gm 3400 V6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2010, 08:13 PM
turbo gm 3400 V6
Ok so I'm trying to turbo a gm 3400 v6. i did a head swap with the 3500 lx9 heads that should take me down to 9.1:1 cr redline at 6000rpm i want to run 8-10 psi i haven't decided yet leaning more to the 8 side...... any way from the little i know about selecting a turbo which i dont know much i thought a garret gt3776 would be about what i need http://www.turbobygarrett.com/turbob...20452159-1.pdf at the same time i think it may be to big for what i need i want something that will spool kind of fast but not all lowed from what i can tell i think the 3776 im looking at wouldn't spool quick enough and be all up high. so any input on selecting the correct turbo would be great...
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
GM Turbo 400 trans front seal housing question Gary Shugart Introduce Yourself 1 01-13-2005 02:56 PM
Mating FWD Toyota Transmission to GM 60 Degree V6 Motor dmc12mk3 Transmission - Rearend 3 11-29-2004 02:17 PM
GM 60degree v6 MAF sensor question ChevelleSS_LS6 Engine 4 06-29-2004 11:26 AM
GM 2.8 v6 musky2 Engine 0 01-07-2003 11:02 PM
