turbo help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2010, 10:23 AM
Banned
turbo help
I need someone who really knows turbos to help me out.
I have a Ford 2.3L engine I am in the process of building and I want to know if I should look for a smaller exhaust housing. I'm putting together a fairly stock turbo 2.3L ford engine with a ported head and a 240/240 cam (.050") with a hahn motorsports super 16g turbo.
The super 16G has a 10cm exhaust housing and I am wondering if I should go to a 7cm housing. A lot of people are running these housings to the power levels I want (350hp at the flywheel) pretty easily- but they are doing them on 4g63 mitsu engines- a far different design than what I am working with.
I felt the larger exhaust housing would be a better match for the cam, but since my power levels are relatively low should I look into swapping to a smaller exhaust housing? I can get a 6 or 7cm housing fairly easily.
I won't be instaling this engine for a while, so I do have some time to find these housings, I just want to know if I should look for one.
I probably should just wait and see how the 10cm one performs but I really have no idea, I'm pretty sure I'm the only guy who is running this combo.
Old 05-13-2010, 11:10 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
whats the a/r on the exhaust housing for the two?
Old 05-13-2010, 12:06 PM
Banned
There's the trick. Mitsu doesn't use AR's, I thought that was awfully nice of them...
They go by exhaust housing size, basically there's the 3 I listed, 6,7, and 10. Of course I could open up a 7 to an 8- that's fairly common on DSM's.
Old 05-13-2010, 01:31 PM
Banned
Picked up a used 6cm housing for $20. I's going to port it out some and install al larger flapper. I'll start with the 6cm housing and if I decide to put it on a track I'll switch to the 10cm.
BTW from what I could find the 6cm is about a .45 AR, and the 10CM is about a .80.
There's a fair amount of overlap on the cam I'll be using so I'm curious as to how all of this will work. All I know is that I'm starting with low boost and playing it safe.
Turbo 350 & 550 HP BB Chevy leejoy Transmission - Rearend 4 12-06-2007 09:56 PM
78F150 shortbed 4by-granny 4 speed,300six & 301 turbo jtyler Engine 27 08-25-2007 07:31 AM
modifying a fwd cars strut tower for turbo clearnce - advice needed lowROLLERchevy General Rodding Tech 4 03-10-2006 11:20 PM
pontiac 301 turbo gutted 87442lover Engine 10 04-30-2004 07:27 PM
Backpressure = Bad.... Right?? D M N Engine 20 01-02-2004 04:53 PM
