turbo ideas - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-04-2013, 03:22 PM
spinn's Avatar
At part throttle I am instantly making boost at load, supercharged. I definitely would say the supercharger type is more at part throttle driving around.
  #17 (permalink)
Old 03-04-2013, 03:56 PM
Banned
It depends on what you mean by "making boost" if you mean before the throttle plate then yes, you are- and you are with a turbo system as well in most cases.
If you mean past the throttle plate the term "part throttle" itself means you are operating with a vacuum in the manifold, albeit a smaller one than you would see with a closed throttle at the same RPM but not as much as when you go to WOT where your manifold will see the boost pressure resulting in a negative vacuum value (or boost pressure as it is commonly called).
  #18 (permalink)
Old 03-04-2013, 03:59 PM
spinn's Avatar
I think the pressure is there sooner.
  #19 (permalink)
Old 03-04-2013, 04:11 PM
spinn's Avatar
If you are working with a turbo and letting out the clutch at 1500rpm pulling up through, and it doesn't get organized until 3500. I was told this is normal.
  #20 (permalink)
Old 03-05-2013, 07:21 AM
Banned
someone lied to you then.
That can be the case for a race type set up but with a good exhaust manifold and turbo lag is almost nonexistent, further more its not exactly RPM dependent as many claim it to be- its load dependent you can actually maintain the same rpm under load and watch your boost pressure rise.
Just like a blower it all comes down to proper sizing for the application.
  #21 (permalink)
Old 03-05-2013, 07:55 AM
Ive driven both supercharged and and turbo vehciles that have made power/boost at part throttle. It all depends on the setup.
peace
Hog
  #22 (permalink)
Old 03-05-2013, 09:21 AM
spinn's Avatar
Now im thinking the ebay kit I used might be a little oversized. Everything is laid out already. I have to assume other people are getting the same drivability result.
From what is available in the aftermarket for my applications, my turbo results were somewhat soft from the line. In comparison to a supercharger kit, on a stock vehicle of the same make/model.
Do you mean, that a kit could be fabricated to deal with the issue, or the ebay turbo kits do not have this concern. Generally speaking?
  #23 (permalink)
Old 03-05-2013, 09:35 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
The one thing I like about turbo's is it the power adder that is the easiest on a engine.Nitrous being one of the hardest.
  #24 (permalink)
Old 03-05-2013, 09:51 AM
spinn's Avatar
I thought originally that the difference in part throttle power and drivability spots were due to the placement of the compressor.
A turbo pushes from in front of the throttle blades and a roots supercharger pushes on the inside. Behind the throttle plates. Less compressible atmosphere between the locations.
  #25 (permalink)
Old 03-05-2013, 09:54 AM
Banned
"ebay turbo" is meaningless as there are some very good turbos on ebay and some very ****ty ones. A well made header/manifold and a properly built turbo will not have any lag problems.
The cheapest **** you can find on ebay is likely not well made nor properly built- BUT you can find quality parts on ebay too.
A turbo needs to be properly built- just like building an engine. There are many different center sections, wheels, housings, wheel/housing modifications, etc. that all need to come together. And then there's the manifold/header side, which is a little more straight forward but still needs proper attention.
  #26 (permalink)
Old 03-05-2013, 09:57 AM
Banned
I think you mean less compressed volume. As for that volume, its very negligible, with turbo ducting you're more concerned with dynamic pressure loss.
  #27 (permalink)
Old 03-05-2013, 12:09 PM
spinn's Avatar
On the auction listings, most of the kits under $1000 are pretty similar. I had my doubts, but coworkers got them. No major problems in over a year of adult daily driving. I am satisfied that the bushing turbo kits are fine if you only want 5-10psi.
I have been told again, its normal.
From tech, Proper turbo sizing requires matching the compressor and turbine assembly. These parameters dictated a range of optimum efficiency. This range falls within an rpm band, referring to impeller rpm. Set up so engine torque peak is close to the peak efficiency island.
Then there is a graph for the units performance map.
A roots type, probably tells you the same thing.
  #28 (permalink)
Old 03-05-2013, 12:22 PM
bigdog7373's Avatar
Of course it's fast
I think i posted this on another thread. Check out cxracing.com. They have the highest quality "ebay turbo's". I'm planning on using their t70 kit. They have great reviews and awesome prices. I highly recommend them.
  #29 (permalink)
Old 03-05-2013, 12:41 PM
Banned
a big difference between a turbo and a supercharger is that the supercharger's speed is dependent on the rpm of the engine- the turbos speed is dependent on energy of the exhaust to drive it- which means the impellers speed can vary INDEPENDENTLY of the engine's speed. Most people don't realize that.
And yes a roots blower will have the same type of chart but the lines are shaped differently.
Another aspect often overlooked is that the compressor and exhaust sections can be adjusted independently on turbos- both the housings and the wheels- but they have to work together for a particular application. Having either side mismatched will result in less than optimal performance.
  #30 (permalink)
Old 03-05-2013, 01:05 PM
bigdog7373's Avatar
Of course it's fast
Another pro for turbo's is that you can brake boost while rolling which allows for the turbo to make peak boost before you even take off.
need ideas on how to support a heavy turbo Pupsvette76 Hotrodding Basics 4 04-14-2012 12:56 PM
New to the form. Ideas for a 454 80mm turbo. chevygurl77 Introduce Yourself 1 09-21-2010 03:57 PM
Nitrous Or Turbo???any Ideas Appreciated tomcraft Engine 6 07-10-2009 11:53 AM
twin turbo ideas? jamesinark Engine 15 04-24-2006 12:02 PM
455 single or twin turbo ideas Jared Engine 30 04-22-2006 01:04 PM
