turbo oil drain question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2012, 08:30 PM
Pupsvette76's Avatar
Last journal entry: no spark and fuel pump issue
i have a sbc 355 with a turbo on it and its mounted very high up on the passenger side its actually right above the passenger side valve cover my question is if it would be ok to route the drain hose into the valve cover the hose would only be about 6 inches long cuz it would be hard to get around everything and down to the pan ... i was thinking about putting a fitting into the valve cover or rigging something into the filler hole of the valve cover... what do u guys think?
Old 02-11-2012, 09:34 PM
1996thunderchicken's Avatar
ALL AMERICAN MADE
The only problem id see would be more pressure on the valve cover if you ever get a clog in the oiling system
Old 02-12-2012, 07:24 AM
as long as the turbo drain is lower than the valve cover it should be ok.
Old 02-12-2012, 09:46 AM
i dont know if it could get clogged...the hose is -12an... yeah i wasnt sure if there could be a such thing as to much oil in a valve cover while the engine running
Old 02-12-2012, 05:39 PM
Anybody have any idea of any products made for that or if I'm just stuck using a bulkhead through the valve cover
Old 02-12-2012, 06:12 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
http://www.google.com/products/catal...ed=0CG4Q8wIwAQ
http://www.google.com/products/catal...ed=0CHQQ8wIwAg
Old 02-12-2012, 06:38 PM
ALL AMERICAN MADE
i wasnt talking about in the line off the turbo i was talking about the passages inside the engine block make sure to keep all oil changes current and keep any crud you can out of the engine other wise you will have catastrophic failure not only to your engine but to the turbo to but any way good luck with your project and i hope that everything falls into place for ya
Location of OEM Turbo 400 drain plug??? jimfulco Transmission - Rearend 7 10-29-2008 09:42 PM
Turbo 350 question Vettkeeper Transmission - Rearend 2 11-08-2007 07:33 PM
Coolant drain question trenchdog73 Engine 3 04-07-2006 02:19 AM
Converter drain question Jmark Transmission - Rearend 1 03-21-2005 09:11 PM
a turbo question. Super Chevy Engine 16 01-24-2004 02:44 AM
