turbo rat rod. need advice! carb 289 vs 5.0 efi - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2010, 06:04 PM
as the title suggests, I am building a rat rod with twin t3/t4 turbos. I have the option of running either a carb 289 from a first gen mustang, or a 5.0 efi from a late 80's/ early 90's cougar with either form of fuel managmentfor both. the trans will either be the 4spd auto from the cougar with the efi, or a c4 for the carb. i was considering a draw through set up for the carb (limited budget for blow through). I like the idea of efi, but I'm biased and need a second opinion, or two.
Old 06-24-2010, 08:09 PM
Irelands child's Avatar
Why EFI on a 5.0? They, IMHO, very aren't nice to look at!! You open yourself up for lots of extra work and "claptrap" from finding a place for a computer module, a high pressure electric fuel pump, a return fuel line, O2 sensors and much extra wiring to name a few odds and ends. The way I define a 'rat rod' is simplicity. If you have a 5.0 EFI it's very easy to convert to carb and C4 tho one from a 289 wont work unless you change the bell housing and use the correct 50 in oz flex plate for the balance. My AVATAR car has a crate 5.0 (manufactured in 1999) with a carb, mechanical fuel pump and a C4. The unused OEM EFI stuff was easily sold, with a Performer RPM intake and carb, an MSD ignition and a new front timing cover to handle the Carter race fuel pump as well as a Stewart NASCAR water pump.
A 289 - why? There are too many 302/5.0 engines and there are way more after market parts available (tho a 289 can be a screamer)
Dave W
Irelands child
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
EFI to Carb conversion advice needed 1953 Homer Engine 2 12-19-2006 11:16 AM
5.0 EFI & AOD INTO 55 FORD WAGON FORD 2DR Engine 8 03-25-2006 08:17 PM
modifying a fwd cars strut tower for turbo clearnce - advice needed lowROLLERchevy General Rodding Tech 4 03-10-2006 11:20 PM
Radical rat rod cuttingedge Suspension - Brakes - Steering 3 02-14-2006 07:52 AM
