turbo sbc ?'s - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2009, 06:19 AM
turbo sbc ?'s
Want to go to the next level w/ my el camino. full roller 385 600 lift and 587 exhaust 248/258 @050. dart pro 1 200 heads. flat tops, forged rods and crank. Really want to boost this thing. either a procharger, weind or turbo. It has 10.7:1 compression and it will never be a street car. I would not mind running 118 octane either. Can it be done safely? what boost psi can I or should I run?
Old 05-20-2009, 06:52 AM
72fordlb's Avatar
BARN BURNING BIG BLOCK!
Well thats a good idea but unless the bottom end is strong that compression is alittle high for a turbo. Now im not sure thats just my guess.
Old 05-20-2009, 07:26 AM
a little out of my experience range, but 118 octane makes boost on a high compression engine possible.
not a good turbo cam, but a pro-charger should work.
your engine should easily run on 93 or 91 octane now, so I feel a moderate amount of boost will be tolerated with 118 octane. Say, 7 or 8 psi which should add 50% more power. so if your engine is making 475hp/450 ftlbs now then it would make 710hp/675ftlbs with 8 psi of boost.
Old 05-20-2009, 11:05 AM
Johan Lokander's Avatar
Dont you have E85 in the states?A EFI and 2 big turbos our 1 BIG turbo shuld work fine whith that compression.The hardest thing probobly is making the tiers hook up and/our the transmision survive
Twin Turbo SBC build, need help SBC S-10 Engine 28 09-11-2013 06:10 AM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
78F150 shortbed 4by-granny 4 speed,300six & 301 turbo jtyler Engine 27 08-25-2007 07:31 AM
pontiac 301 turbo gutted 87442lover Engine 10 04-30-2004 07:27 PM
powerglide vrs turbo 400... sbc 355 Dave Y. Transmission - Rearend 5 11-08-2002 03:34 PM
