Holley makes a mechanical secondaries 600 cfm carb specifically for blowers, how would that work?
Here it is: http://www.holley.com/0-80592S.asp |
thats what you need but if you can get one with a higher cfm i would cause 600 isnt much at all,i would go 750 on a simi-stock motor. And look at what blower/supercharger you want.
http://www.holley.com/0-80572S.asp Try this
whao wait i forgot this is going on a 292 inline yeah 600 cfm will be plenty im sorry you were right. try this too http://www.holley.com/6500-1.asp
honestly carbs and turbos ive never messed with but that is the carb you need with forced induction. i would check on the carb and see if it will withstand the pressure of a turbo that size.
One thought. I've had REALLY good luck with the WH1C turbo from a 12 valve cummins on a ford 302. Match made in heaven. Stock, the WH1C will do 16-18 psi, and the turbo has many CHEAP upgrades available. Even the rebuild kit is cheap (it's like 75 bucks).
if you really want A turbo get one from a ford super coupe. i found one last week but some one already yanked the turbo. super coupes came turbo or supercharged.
dang. this thread died too... shame...
If I were to pick for this engine I would go with an HY35 over the WH1C. It has updated wheels, and will spool faster. They are available very cheap on ebay. Just make sure and stay away from chinese crap. Any of these diesel turbos will require a different wastegate actuator so you can bring the boost down to 8-10 range. You will want it there to start tuning. You can run more on some combinations(I run 25psi with two stages of water and c114 fuel), but for a street engine 8-10 is pretty safe to start. I am assuming you also understand how to setup fueling and timing control for an engine like this. If not, ask and we can discuss. |
| Settle the age old Charger debate | PINKINDIAN47 | Hotrodders' Lounge | 32 | 04-27-2010 09:26 PM |
| Looking for 66 Charger Mods, Aftermarket Support & Forum | Elevinpointsixtoone | Hotrodders' Lounge | 19 | 12-21-2007 05:37 PM |
| C4 Corvette Turbo/Super Charger | blakblur | Hotrodding Basics | 11 | 07-31-2007 02:52 PM |
| Battery Charger is messed up? | ChevelleSS_LS6 | Garage - Tools | 2 | 02-09-2006 11:17 PM |
| Dodge Unveils Sketch Of New Charger | TNTster | Hotrodders' Lounge | 18 | 10-15-2004 10:59 AM |
