turbo/super charger - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 07-08-2010, 11:47 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Originally Posted by QParker
wouldn't the 12 valve turbo spool up later? It's a 359ci engine compared to a 292ci, a 67 cubic inch difference...
Would the t4 turbo work?
I don't know much about turbos, so please clue me in...
What would a t4 actually be intended for?
A gasoline engine will typically take a larger turbo due to higher RPM operation. In this case, they are pretty close so the automatic version I listed, HY35W, with 9cm turbine housing will spool very quickly. The compressor also utilizes a map-width enhancement ring which will make it more tolerant under low boost operation and will be less likely to surge.
  #32 (permalink)
Old 07-08-2010, 11:50 AM
TurboS10's Avatar
Wiki Edits: 2
Holley makes a mechanical secondaries 600 cfm carb specifically for blowers, how would that work?
Here it is:
http://www.holley.com/0-80592S.asp
No dice. That is designed for a draw through supercharger application. You will want to go blow-through on all of these turbos listed. Plus, performance is better with blow-through. There are carbs available, but you can do a $50 rebuild on a used carb and set it up for blowthrough. You just want to start with one that has good tight throttle shafts so you dont have to worry about sealing them.
  #33 (permalink)
Old 07-08-2010, 05:57 PM
Who ever said this thread died?
Can a man go fishin?
Is that okay or do I have to get permission from you guys so you don't close my thread?
My apologies for earilier. that comment wasn't directed towards you. It actually wasn't even about this thread. Just read through this post, you'll understand.
4.3 V-6 with LT-1 TPI?
  #34 (permalink)
Old 07-08-2010, 06:00 PM
Qparker, I actually LOVE the fact that you're working with a 292. I was going to go a similar route with my old c10, but I'm going with a vortec 4200
you could also mod a clifford intake for multi point, and run mega squirt. THAT would be awesome to see.
  #35 (permalink)
Old 07-08-2010, 11:42 PM
QParker's Avatar
Six Offender
NO FUEL INJECTION!!!
I already feel bad about putting a motor from the 70's in my '49 pickup, let alone putting a turbo on it...
I figured i would atleast keep it a straight six...
Now, if anyone wants to donate a 12 or even 24 valve cummins that's TOTALLY different, not an ounce of guilt
would be felt there...
And cusz28, I was just givin ya a hard time, no apology needed
  #36 (permalink)
Old 07-09-2010, 12:04 AM
QParker's Avatar
Six Offender
Or a duramax...
  #37 (permalink)
Old 07-11-2010, 09:25 AM
GN turbo
I have been down this road before. I just completed a complete turbo system on a chevy inline 250. I runs really good. Get a turbo off of a 86-87 Buick grand national. Use a small 350 or 500 cfm Holley two barrel ( 2300 series) they are very easy to modify. If you get serious, pm me. I will walk you through it. good luck
  #38 (permalink)
Old 07-26-2010, 01:09 AM
QParker's Avatar
Six Offender
what about some of the small diesel blowers, like one off of a 4-52 or a 4-71?
  #39 (permalink)
Old 07-27-2010, 11:37 AM
QParker's Avatar
Six Offender
bump
BumpBumpBump
  #40 (permalink)
Old 07-27-2010, 11:38 AM
QParker's Avatar
Six Offender
I do have A 6-71 blower Handy, and I think I'll try to use that. I'll probally have to mess with pullys to get the right ratio.
Here's how the thread is going elsewhere:
"There is a guy on the H.A.M.B site running an 8-71 on his 270 six, and he says it can keep up with the stupid little ricers on the highway, so I was thinking my 6-71 would probably work fine.
I'm not looking for a full out race motor, but I want to be able to show those ricers what a real hot rod looks and sounds like
If I get 350HP and 350ft.lbs I'd be happy, It'll top at about 10psi boost and 6000 RPM, and It's going to be a daily driver anyway...
Hank, Or somebody, Could you please suggest some cam specs for me?
That'll have me running a Holley 600 (http://holley.com/0-80592S.asp), Clifford intake, lump ports, 1.94I/1.50E valves, Long tube headers, Ross Pistons, and the 6-71 Blower. "
Settle the age old Charger debate PINKINDIAN47 Hotrodders' Lounge 32 04-27-2010 10:26 PM
Looking for 66 Charger Mods, Aftermarket Support & Forum Elevinpointsixtoone Hotrodders' Lounge 19 12-21-2007 06:37 PM
C4 Corvette Turbo/Super Charger blakblur Hotrodding Basics 11 07-31-2007 03:52 PM
Battery Charger is messed up? ChevelleSS_LS6 Garage - Tools 2 02-10-2006 12:17 AM
Dodge Unveils Sketch Of New Charger TNTster Hotrodders' Lounge 18 10-15-2004 11:59 AM
