turbo/super charger - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2010, 04:33 PM
QParker's Avatar
Six Offender
turbo/super charger
What are some commonly found cheap turbos or blowers found in junkyards that are going for pretty cheap? They need to fit engines between around 230 and 300 ci.
It may be going on a 292 straight six... depending.
Old 06-29-2010, 07:54 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
MP90 or MP112 are production superchargers that are available. The mp90 is more available then the mp112 for sure. It came on 97-04 grand prix gtp and buick SES. The mp90 were designed for 3.8L engines. For a turbo you would have to map out a compressor map and see how much your engine needs and such.
Old 06-29-2010, 08:43 PM
BOBCRMAN@aol.com's Avatar
In my area the 3.8 Buick turbos are around. Same with the 3800 superchargers. But they should not be run with fuel going thru them..
Old 06-30-2010, 01:14 AM
QParker's Avatar
Six Offender
I contacted tom lowe at 12bolt.com and am waiting for a reply on the subject...
Old 06-30-2010, 07:15 AM
Turbos
find an old 300zx or especially a 280z turbo set up cheap and pretty much basic on the 280z. ive converted a small chevy inline with 280z turbo system. you should check into it. other than that call a turbo specielties shop and tell them what you want and they can map it out for you and tell you what all you need.
Old 06-30-2010, 03:22 PM
QParker's Avatar
Six Offender
I found this on Craigslist. Any good? should I check it out?
http://anchorage.craigslist.org/pts/1796180065.html
Old 06-30-2010, 04:33 PM
hmm
not a bad buy but id go smaller. Check out the size of a 280z turbo
Old 06-30-2010, 04:42 PM
QParker's Avatar
Six Offender
Would it work or would it spool up too late to do much during normal driving?
Old 06-30-2010, 04:47 PM
well there isnt enough info on it in the ad
its oil cooled and lubed, he doesnt know if its a t3 or t4,there is no width size stated and he doesnt state if its ball bearing or what so honestly idk... give me a sec.
Old 06-30-2010, 04:51 PM
QParker's Avatar
Six Offender
Or this?
http://cgi.ebay.com/ebaymotors/Eaton...Q5fAccessories
Old 06-30-2010, 04:56 PM
maybe
it could work but i would go with a large intercooler and an adjustable boost control valve plus without looking at it idk if it really has a iwg or ewg. But it should do fine with your motor but you will still need a professional to map it out for you and tell you exactly what you need and what goes where. BUT like i said i cant really identify the brand, pitch on blades, bearing type, or actual size so i would w8 and get a new one that you know what you're buying...
Old 06-30-2010, 05:00 PM
eaton
eaton is a good brand plus a s/c can be alot less technical is your motor going to be fuel injected or carbureted.
Old 06-30-2010, 05:38 PM
QParker's Avatar
Six Offender
It will have a Holley 4bbl... You can't use vacuum secondaries with a blow through, Can you?
Old 07-01-2010, 08:42 AM
no you will need something a street demon. try Speedwaymotors.com they have quite a bit of stuff for inlines and a eaton m90 will serve you best if you want a eaton but there are twinscrew superchargers made for carburated applications and they are also on speedway. if you use an eaton you will need a adapter plate of adaption spacer.
Old 07-02-2010, 01:31 AM
QParker's Avatar
Six Offender
Here's that same turbo(i think) on Alaska list:
http://alaskaslist.com/1/posts/10_Tr..._1_15_A_R.html
It has all measurements, everything, it's a t4 for $150. Good deal? will it spool up right with the 292?
Settle the age old Charger debate PINKINDIAN47 Hotrodders' Lounge 32 04-27-2010 09:26 PM
Looking for 66 Charger Mods, Aftermarket Support & Forum Elevinpointsixtoone Hotrodders' Lounge 19 12-21-2007 05:37 PM
C4 Corvette Turbo/Super Charger blakblur Hotrodding Basics 11 07-31-2007 02:52 PM
Battery Charger is messed up? ChevelleSS_LS6 Garage - Tools 2 02-09-2006 11:17 PM
Dodge Unveils Sketch Of New Charger TNTster Hotrodders' Lounge 18 10-15-2004 10:59 AM
