turbo system - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2003, 05:15 PM
turbo system
Anyone know anything about a Martin Turbosystem for a SBC? I ran across a guy who has a complete system(turbo-intake manifold-exhaust manifolds and exhaust pipes) and he wants $600.00 for the complete setup. Question 1 does anyone know anything about the system pro or con and 2nd question is it worth the money he is asking?
Old 12-12-2003, 05:29 PM
badknuckles's Avatar
you talkin to me?
find out how many pounds of boost it puts out and what kind of shape its in
Old 12-12-2003, 05:57 PM
bigblockbill's Avatar
dont listen to bad knuckels hes a toad
use a blower instead
Old 12-12-2003, 06:09 PM
you talkin to me?
bigblock bill its troll not toad ya dumb ase master tech
turbos rock blowers are better but turbos are cool
Old 12-12-2003, 08:10 PM
I don't know anything about that particular kit, but I do know that you've got to put a lot of thought into selecting a turbo. You've got to decide what pressure ratio you want(based on boost), and then plot it on the flow map for the turbo with the airflow of the engine in question. Then you get into choosing the A/R ratio for the turbine. This is all based on what you want to do with it. Long story short, the 600 could be either a steal or a dud. You won't know until you find out what the kit really is. Good luck.
Old 12-12-2003, 08:41 PM
Auto-Part's Avatar
Stay away from it they don't work. Not worth the hassel.
Old 12-13-2003, 11:38 AM
turbo system
Thanks for the info. I don't know anything about the system as to lbs of boost or whatever so if I can't find out anything positive from you guys I am going to stay away from it.
Thanks again
Old 12-13-2003, 11:45 AM
roys63's Avatar
Is this a blow{ blows to the top of carb ] or draw trough [ using a special designed intake manifold] system?
Old 12-14-2003, 10:41 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
I would be willing to bet, even without seeing it, that it is a draw through system designed as a bolt on for use with oem quadrajet. It could not be much more for that price. Proabably has a single turbo on one side with a crossover. Supposedly those systems work well on stock engines. Show us some pictures and I can tell you better what to expect. You can tell most of the above is troll info, so dont take it to heart. Let us know.......
Chris
