Turbochargers - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2002, 03:30 PM
Post Turbochargers
Im going to scrounge a pair of turbos for my 302 out of the junkyard, building the 302 as practice for the 4.6 I hope to build. What production turbo cars had decent size turbos?
Old 03-08-2002, 12:36 PM
New Member
Post
If you were to find a shelby daytona,a t bird turbo coupe,grand national all of those have pretty decent turbos to begin with.In the near future i plan on turbo charging my dads k car with the urbo out of my 86 shelby daytona.
And on the 13th day god created...........MOPAR.
Old 03-28-2002, 10:25 PM
drgnwgn289's Avatar
Post
Newport is right, but the chances of finding say, a grand national in a junkyard....pretty slim. If you are gonna put dual turbos on it, check out some Audis, Volvos, and some mid 80s chrysler sedans. They are usually overlooked.
Good luck
Old 03-29-2002, 01:25 AM
New Member
Post
First of all for performance and price you are better off sticking with the 302. and fitting a 302 with used turbos is not even somthing you have to invent all your self, Try this link out:
<a href="http://www.geocities.com/windsor_302/TurboPartslist.html" target="_blank">web page</a>
This guy have built 302's with upwards of 5-600hp, with 450$ worth of parts, add bigger mass MAF, B303 cam and an intake and your dooing 10.5 sec ET's with less than 1000$ invested
and whats best about this page is that there is an online calculator for determining the compressor trim and A/R ratio for the engine your building, plus a list of what donor cars to take them from.
Hope this helps
Old 03-30-2002, 07:24 AM
Post
What is you opinion of the 302 crank and rods holding up under a lot of boost?
Old 03-30-2002, 06:37 PM
4 Jaw Chuck's Avatar
Post
Boost won't hurt the rods or the crank but RPM sure will, keep it under 6000 and you should be just fine.
— Han Solo
Old 04-01-2002, 12:36 PM
New Member
Post
for what o know stock rods and cranks are good for atleast 500 horses, just keep the revs below 6 grand, infact if i know of 5.0,s doing 10.00 et,s with stock shortblocks and AOD trannies, but they dont last forever. My Recomendation would be to put a set of HiPo 289, heads or the 5.0 heads of an explorer, they flow decently. then mount two turbos from a firebird turbo, (T03 A/R .63) and keep the boost below 14PSI and revs below 6G and you'll be doing high 11,s and that on an investment of under 1000$
Old 04-02-2002, 12:23 PM
Post
That ought to do it... I just want to beat a friend of mine that has close to 40 Gs sunk into a 12 second import...
Old 04-02-2002, 02:00 PM
Post
Can i get away with a carb or am i gonna have to inject this thing... Ive got a set of 5.0 heads from a 82-84 stang that has about 500 bucks worth of porting.... I dont know all the details, but they should do...
Old 04-02-2002, 02:08 PM
1meancuda's Avatar
At a loss for words
Post
You should be okay with a carb. Just be sure that it is a big enough one and is up to the challenge that the twin turbo will give it.
Good luck on your project. Keep us posted!!!
Old 04-02-2002, 08:39 PM
mustang66maniac's Avatar
Ford Freak
Lightbulb
Just wanted to set something strait. 289 hipo heads are too often thought of as a bigger head than the regular 289 head. As a matter of fact, the 289 hipo head is the EXACT same except it has valve spring seats so its more stable for high RPMs. They actually have IDENTICAL ports and valves.
Old 04-02-2002, 08:58 PM
drgnwgn289's Avatar
Post
JdOwNj,
Like someone else already said, make sure to get a big enough carb. You can alway go down in jet size, but you want to be able to flow as much air as possible. I use a 725 cfm on my supercharged 289, I had to do a lot of tuning to get it right, but it runs good. I would suggest a new Carter AFB or an Edelbrock (the only difference is about $80), they are easy to make work on pressurized motors. Also, if you have enough hood clearence (or don't mind putting in a scoop) then I would suggest a draw-through system as opposed to a blow-through.
Old 04-03-2002, 11:56 AM
New Member
Post
First of all we agree that the heads are the same, HOWEVER the old style (pre emisions) 289 heads do not have the flow impeeding bump in the exhaust, making them better for turbocharging. but if you have a set of ported 5.0,s you are propably much better off using them. Just make sure that the exhaust seats are wide enough as they run rather hot on a turbo car.
With regards to a carburator id advice against it, atleast go with a blowthrough setup.. this will enable you to run an intercooler, (something home made from the local Semi junk yard is arround 100$) but a complete injection setup from a wrecked 5.0 should not set you back to much cash.
again good luck with the project
Here is a couple of home pages of some guys that have done the same thing on some 5.0's
<a href="http://www.sn95.com/projects/turbo/part1.htm" target="_blank">http://www.sn95.com/projects/turbo/part1.htm</a>
<a href="http://www.geocities.com/windsor_302/" target="_blank">http://www.geocities.com/windsor_302/</a>
Old 04-03-2002, 12:32 PM
Post
Where was the Garret T3 installed stock, so that i might find two without breaking the bank? That 450+ hp from an otherwise stock 302 looks pretty cool! Im thinking 8-12 lbs boost...
Old 04-03-2002, 12:57 PM
1meancuda's Avatar
At a loss for words
Post
Everyone can debate and debate, but if you are comfortable running a carb, I'd say go for that rather than try to set up an EFI system. A well tuned and maintained carb can be almost as good as an EFI system (probably without the mileage though). Carbs have less that can go wrong with them than all the different sensors on EFI engines.
If you can find a decent one on a junkyard 5.0, snag it, but just make sure all the components are good. You could end up spending a fortune getting it to work where a brand new carb would simply set you back a couple hundred bucks.
