turbochargers and destroked engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2002, 07:47 AM
Post turbochargers and destroked engine?
hey its me again <img src="graemlins/sweat.gif" border="0" alt="[sweat]" /> can any one tell me if turbocharger and destroked 350 sbc work okay togather and what do i need if its okay to install i turbo on my destroked 350 thanks again
Old 10-12-2002, 12:27 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
Yes it will work, and work very well if it is set up correctly. I will assume you want to drive it on the street so I will lean toward that in the info. It is better to build the engine low compression if possible. It is possible to run compression and boost, but less compression will tolerate more boost and yeild more power on the same fuel. You want fairly small port intake and head ports as air velocity is what makes turbo motors work. Fuel injection is better, but for those of use on a bugdget a blow throuhg carb will work. Holley is the best.
The block should be o-ringed, and studded everywhere to keep things in place. The internals dont have to be any different than that of an N/A motor. As long as you dont rev to high(over 6000ish), turbo motors will generally handle more power on weaker parts.
As for the turbo, I could spit model numbers at you, but you should really go learn how to read compressor maps and learn how turbos work and figure out what you need. That said, Holset HX40 is good for about 650HP, Garrett GTP38 is good for about 550HP, Pair of Garret T3 60 trims are good for 650HP, and a pair of Garrett T4s will make anywhere from 600 to over 1000 HP depending on model. There are also T4's that will make over 600 HP alone. I would suggest you read "Turbochargers" by Hugh McInnes and "Maximum Boost" by Corky Bell to learn the concepts.
There are alot of things you have to understand to make a turbo motor work, so if you are serious start doing some homework. There is also a group called JYTURBO on yahoo that is a wealth of info.
Chris
Old 10-14-2002, 06:20 AM
Post
thanks for the good info chris i well be a big help ill do my best to learn more about it sorry to take your time <img src="graemlins/sweat.gif" border="0" alt="[sweat]" />
.....blue ray.....
