Turn-Key Components - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2006, 08:51 PM
Turn-Key Components
I've never put together a 'turn-key' engine, so I'm not sure what additional items I'd need. ie: ignition, etc. for this to be considering 'turn-key'
this is what I've got so far:
Block: http://store.summitracing.com/defaul...7&autoview=sku $679.60
Camshaft: http://store.summitracing.com/defaul...5&autoview=sku $109.95
Heads: http://www.jegs.com/webapp/wcs/store...tegoryId=78237 200k Intake $999.99
Water Pump: http://store.summitracing.com/defaul...rchType=Engine $89.95
Ignition: ???
Rotating Assembly: http://www.speedomotive.com/383%20AL...RANK%20KIT.htm (64cc) $1575.00
Push Rods: http://store.summitracing.com/defaul...=egnsearch.asp $109.39
Fuel Delivery Kit: http://store.summitracing.com/defaul...=egnsearch.asp $215.88
Oil Pan: http://store.summitracing.com/defaul...=egnsearch.asp $28.88
Valve Covers: http://store.summitracing.com/defaul...=egnsearch.asp $50.95
Total: ~$ 3,860
thanks.
Old 03-29-2006, 09:10 PM
From the looks of it, you'd be better off buyin' one of those GM Goodwrench performance crate engines.
Old 03-29-2006, 09:19 PM
But do they have them with fully forged 4340 steel internals? crankshaft, rods, & pistons?
Old 03-30-2006, 06:38 AM
but remember...you get what you pay for....chinese forged parts are cheap.
Old 03-30-2006, 07:53 AM
MI2600's Avatar
Member# 3287
My opinion...waaaaaay overkill.
Old 03-30-2006, 12:55 PM
I just don't want it blowing up on me with a few 200 shots...
Old 03-30-2006, 01:34 PM
Buying and assemblying an engine like that is very very expensive. There are lots and lots of little things you need. You still need alternator, distributor, carb or efi, radiator, thermostat, bolts and studs,oil pump, gaskets and more
You should look into buying a 350 motor and then replacing internals and such. The block your looking at is cast anyways, so just buy a stock 350 block. They can be had for around $100
Or buy a crate engine, i hope you got deep pockets
Brendan
Old 03-30-2006, 02:51 PM
johnsongrass1's Avatar
Race it, Don't rice it!
IF you buy a junkyard block then your gonna have $750 dollars in the thng anyway so why not buy it from summit? I see nothing wrong with what your doing here. If you have the money to spend for the forged internals means you'll get more relaiblity and you just might get enough to make two or three more builds using the same stuff.
95 Camaro fan switch problem / ignition key problem human_forklift Electrical 12 05-29-2015 08:57 PM
Turn key crate motor socalroadster Engine 1 08-18-2005 07:18 PM
turn signals impala dreaming Electrical 5 02-24-2003 07:29 PM
Steering Column wiring fred56 Electrical 6 12-07-2002 11:16 AM
turn key but no ones home jeff germano Engine 3 12-07-2002 12:38 AM
