Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - turn key, no crank
Old 10-25-2012, 04:18 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Check all starter connections for tight with no corrosion and make sure you have a good ground. You should have a ground to the engine from the battery and a ground from the engine to the chassis and ground from engine or chassis to the body (you can't have too many grounds IMO). It could also be the ignition switch or neutral safety switch going South.
