Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - turn key, no crank
Old 10-25-2012, 05:20 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
clean
X2 on clean the battery cable connections. Better yet replace the battery cables. Unseen corrosion can occur inside the terminal lugs which can cause the problem you describe.
vicrod
