Turn Signal - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2007, 02:44 PM
Turn Signal
I have a 66 Mustang. The Turn signal switch was bad and I had it replaced. The guy that replaced it cut the wires from the harness between the column and plug. He attached the wires now when I turn on the right turn signal it flashes front and rear. If I turn on the left signal the front and left flash and so does the rear right signal. I have no brake lights when brake is applied. What can I do to correct this, when I confronted the mechanic he stated everything worked fine when it left the shop. It looks like the new wires color coding isn't the same color code as original. How can I correct?
Old 07-16-2007, 04:17 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Sounds to me like the guy that wired it up didn't have a Clue..Or was color blind..
The wires that you should have from the lamps , should be as follows..
IF the wire color coming OUT of the switch differs , He put in the WRONG switch, remove , and replace it with a proper switch, then follow the wire colors.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-17-2007, 05:45 AM
Wiring
Thanks Doc I will try diagram hopefully I can fix and get my car back on the road. Don't need police pulling over for no brake lights or rear tail lights all blinking. Will keep you informed.
old column mount turn signal whatwouldscoobydo Electrical 16 07-13-2007 08:07 PM
78 camaro turn signal help hcker2000 Electrical 16 06-15-2007 04:06 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
crazy right turn signal fasteddiesage Electrical 6 02-07-2006 10:33 AM
turn signal blowing flasher fuse RodFather Electrical 12 05-13-2005 06:23 PM
