Turn signal/ Brake Problem (1964 Bel Air) - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2011, 10:41 AM
ComradeNorgren's Avatar
Hey guys, so after replacing my turn signal housing assembly because the assembly in it before didn't automatically turn off the turn signal i've had nothing but problems, anyways the latest problem i've run into is my turn signals stop working when the brake is applied. Have any of you had a similar problem with this? Do you guys think it's the bulbs? or just a short somewhere? either way i greatly appreciate any info you guys have on this! It's frustrating beyond belief.
Old 07-17-2011, 01:28 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The attached schematics are a typical GM turn signal, brake light, hazard setup.
Any time the brakes are applied while the turn signal is on, the rear flashing turn signal will continue to flash and the opposite side rear bulb will light steady.
Make sure all the wires are connected per the attached drawing.
vicrod
Old 07-17-2011, 04:23 PM
EOD Guy's Avatar
Sounds like you got a crossed wire somewhere, as Vic said trace your wires
Rear brake light/turn signal problem new wiring. bobwire Electrical 3 12-13-2009 04:57 PM
brake light and turn signal wiring slammed 57 Electrical 4 10-28-2009 06:25 PM
79 TA: hazard, right turn signal, brake signal out Gladis Electrical 6 12-25-2007 10:06 PM
brake light, turn signal, tail lamp problem worknprogress72 Electrical 6 01-06-2006 12:20 AM
turn signal and brake light problem PrimeMover Electrical 5 05-27-2003 06:26 PM
