turn signal dilema!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2002, 05:11 PM
Post turn signal dilema!!
I am building a 31 Model A street rod. Looking for front turn signal options. Have't found anything I like so far. I am using King Bee headlights. I know you can get signal assemblies that will mount inside the headlight buckets but, I don't really want to drill holes in the bucket. Anyone have any suggestions for other options. Thanks
Eric
Old 04-12-2002, 08:29 PM
Post
I have seen some that sit in the end of the frame, they are they same shape as the end of the frame rail thought they were pretty trick. Not sure who made them sorry. How about some LED'S from someone like Ron Francis at <a href="http://www.wire-works.com" target="_blank">www.wire-works.com</a> Check them out. LED'S are great cause they dont take up alot of room and they are very bright for their size.
Hope this helps. take care.
Old 04-13-2002, 05:09 AM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Post
1.0 I have seen front spreader bars that have turn signals in them.
2.0 If you are running full fendered you could install cowl lights and use them as turn signals.
3.0 Or do as I do, stick your arm out the window and signal the old fashioned way, its a lost art!
Old 04-13-2002, 10:30 AM
Post
If your looking for a really clean look, with use of a couple of heavy diodes,a flasher, & a relay you can make the left headlight blink for a left turn and the right for a right turn.Paulweldit
[ April 13, 2002: Message edited by: PAULWELDIT ]</p>
Old 04-14-2002, 01:06 AM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
you could also use motorcycle turn signals, stock or the custom, they have many great styles and shapes sold aftermarket, I've seen alot of rodders use them, I myself have used them, its not very exspensive, reletively simple to hook up and alot easier than the alternatives
