Turn signal dimming dash instruments? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2007, 08:27 PM
chewyscool's Avatar
Big Block 454
I'm having my dash lighting dimming hi and low when i use my signals, also notice that my voltage meter goes from 12 to 14 as the signal operates. Any ideas as to what the problem might be? (other than the system is 40 years old)
Old 08-10-2007, 09:14 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
What year Car?
What model Car?
Generator or Alternator?
Internally regulated or Externally regulated?
Do you have a properly bonded ground Buss system?
Doc
Old 08-11-2007, 10:57 AM
chewyscool's Avatar
Big Block 454
67 nova, alternator, 1 wire, internal regulated I would say due to the one wire, ground bus need to know more, thanks.
Old 08-11-2007, 11:00 AM
chewyscool's Avatar
Big Block 454
hey doc i live in lafayette too....... Lafayette, La.
Old 08-11-2007, 02:18 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Your pretty much STUCK with the low RPM drop outs with a one wire alternator,as they have NO provision for remote sensing of the regulator..
Maybe time to consider an upgrade..
Why did you install the one wire anyway?
Doc
Old 08-11-2007, 02:21 PM
chewyscool's Avatar
Big Block 454
the car came like that, what kind of upgrade would you suggest.
65 Impala Turn Signal Question EazyDuzIt102 Electrical 4 03-26-2006 11:54 PM
Universal turn signal install mbmopar Electrical 2 03-04-2006 09:26 AM
brake light, turn signal, tail lamp problem worknprogress72 Electrical 6 01-06-2006 12:20 AM
Turn signal switch on column 49dream Suspension - Brakes - Steering 1 04-27-2005 08:00 PM
turn signal and brake light problem PrimeMover Electrical 5 05-27-2003 06:26 PM
