turn signal flasher - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2009, 07:34 PM
turn signal flasher
I have a 2 post flasher that right now has current flowing from one post to another without the turn signal on. Is this normal or would this flasher be bad? I had turn signals and suddenly I don't, I would a bad flasher with the contacts fused together cause this?
Old 01-22-2009, 08:15 PM
Wiki Edits: 27
flashers
normally turn signals work with the key on or in the acc position , current flows thru the flasher to the turn signal switch. move the handle to contact the front and rear contacts. A 2 prong flasher needs the right amount of resistance to heat up the element in the flasher can. like your toaster getting hot before it pops up. if you are using a low wattage test light you will show power at the flasher. not enough resistance to operate the blink mode. when one light bulb burns out they would blink at a different rate. because of the different resistance load. use your emergency flasher to check the bulb operation. if they work ok it's probably your turn switch. If the EM flashers don't work check the grounds.
Old 01-22-2009, 08:26 PM
Thank you for your help
79 TA: hazard, right turn signal, brake signal out Gladis Electrical 6 12-25-2007 11:06 PM
Universal turn signal install mbmopar Electrical 2 03-04-2006 10:26 AM
turn signal blowing flasher fuse RodFather Electrical 12 05-13-2005 07:23 PM
Turn signal flasher Seon Electrical 10 12-05-2003 11:34 AM
Location of turn signal flasher unit SteveMach1 Electrical 1 11-21-2003 08:46 AM
