turn signal flasher/ LED
Hello, If I am putting LED bulbs in place of my original bulbs for turn signals, what will my flasher do? My buddies tell me it will flash real fast, I feel that it will not flash at all. My reason for thinking this is because I remember years ago when I pulled a camper trailer I had to install a different flasher because the original flasher blinked real fast with the extra load on it. So my thought is that with LED bulbs I have LESS resistence therefore it would NOT let the original flasher work. Who will be right?
And if I am right, will my turn signal lights come on and stay on or will they not light at all? Thanks, Rick Oh yeah, we all agree that I will need a different flasher, where is the best deal for a GM flasher for the LED application? Thanks again |
Your logic sounds right - lower resistance may cause it to not flash at all, or extremely slowly.
If you have a fairly standard vehicle you should be able to buy an LED-compatible flasher at any of the parts stores (Autozone, etc.). If your vehicle uses a flasher that is hard to find (the case for some foreign vehicles) you can add a load equalizer to the circuit and the original flasher should work. Bruce |
I assume that your trailer flashers were wired in parallel, not in series. Series would increase resistance, parallel would reduce it. But yeah, a special flasher or an in line ballast is the solution.
BTW . . .I'm 99% certain they'll blink fast without the special flasher or the ballest. PatM |
| flasher for turn signal | rick laplante | Electrical | 11 | 05-21-2009 10:41 AM |
| turn signal flasher | coolcars58 | Electrical | 2 | 01-22-2009 07:26 PM |
| Turn signal flasher question | sexypizzaman | Electrical | 2 | 09-20-2008 08:59 PM |
| turn signal flasher and bulb? | 39chevy | Electrical | 4 | 02-04-2008 07:51 AM |
| Turn signal flasher | Seon | Electrical | 10 | 12-05-2003 10:34 AM |
