Turn signal indicators - both light up now - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2009, 09:53 AM
4t64rd's Avatar
Hoodlum
OK, I was partially through wiring up the front clip using an all black EZwire kit (circuit name printed every 6" on each wire)
And I had the front turn signals working right, and the dash indicators for them too... blinking, slowly, since there was no rear lights hooked up to provide resistance...
I've since had to shorten the two indicator light wires and now when I try them, both indicators come on at the same time... and the front turn signals don't work.
What do I have crossed that would make both indicators light up (but not blink) at the same time? I didn't remove any of the wires for the front turn signals...
Old 02-16-2009, 01:49 PM
Last journal entry: 50 Ply wagon
Did you check your ground wires for a good ground? Check fuses ?
Old 02-16-2009, 04:40 PM
302 Z28's Avatar
Or a bad bulb that is back feeding.
Vince
Old 02-16-2009, 06:28 PM
Cape Cod Bob's Avatar
Check to make sure your hazard switch is not on. BTDT
Stop light and turn signal problem dac Electrical 2 10-30-2008 09:14 PM
50 ford rear turn signal help Edbiosca Electrical 2 07-13-2006 08:45 PM
turn signal issues blufftonboy Electrical 5 05-29-2006 10:44 PM
brake light, turn signal, tail lamp problem worknprogress72 Electrical 6 01-06-2006 01:20 AM
need turn signal switch & advice --help! : ) WayOutCat Electrical 8 05-01-2003 11:56 PM
