turn signal issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2009, 07:45 AM
turn signal issues
I'm attempting to rewire my 63 Chevy C-10 using a painless harness, I have everything almost complete but I'm having an issue with the turn signals. everthing seems to work correctly except when i turn on the ignition both tail lights blink constantly? I have replaced the turn signal switch with an original style switch, brake lights work with the key off, but I still have no turn signals, I have ran separate ground wires to both rear lights. It has me stumped? Any help would be greatly appreciated.
Old 08-24-2009, 08:47 AM
http://static.howstuffworks.com/gif/...nal-wiring.jpg
thats how they work, but im still trying to understand what the problem is.
when you turn on the ignition both tailights blink, is this the brake lights? I just looked at what the tail lights look like on your year truck and it looks to me its pretty small but either way there should be two bulbs in that assembly.
one bulb for turn signal
and one with a dual filament, there will be three inputs on the bulb two + and one ground. The less bright + input should be hooked up to the running lights and the other + to the brake lights
I hope this helps you.
Old 08-24-2009, 09:22 AM
no there is only one bulb in each tailight assembly, a dual filament bulb an 1157. It isnt the brake lights they work with the ignition off. I hear the turn signal flasher clicking on and off but the turn signal switch is'nt being moved in either direction and the front turn signals don't do anything. no matter which direction I move the indicator everything stays in this state both tail lights blink constantly and the front turn signals do nothing? thanks for the reply though.
Old 08-24-2009, 10:44 AM
bobjob's Avatar
on chevys,, left -right - and stop lites are same ,, high side of 1157 bulb.. it all works thru turn signal switchplate..sounds like you are crossed -up there..try unhooking wires at stoplite switch and check..sounds like brake lites are flashing,, because it's only rears.. are you crossed up at emergency flasher switch?? 1 or 2 flasher relays??
Old 08-24-2009, 05:02 PM
T-bucket23's Avatar
Wiki Edits: 26
Did you check to be sure the emergency flasher switch is not turned on?
Chet
Old 08-25-2009, 07:23 AM
theres only 2 wires coming from each tail light. but it's possible that i have them crossed? It has 2 flashers in the new fuse panel 1 for the hazard and 1 for the turn signals. The truck didnt have a flasher switch when I started, I'm now thinking of adding one in hopes to help solve my problem? But the flashing is coming from the turn signal flasher? I know the two are linked together but I'm not sure how? This is my first time trying this. Thanks for all the input anything helps.
Old 08-25-2009, 08:42 PM
Cape Cod Bob's Avatar
Go to this site http://www.oldengine.org
click on the unFAC pages
then click on rear dual lites.
Digest that info and shoot.
Click on schematics and print out them. . to use beside u as u troubleshoot. U may need a voltmeter or at least a pigtail and bulb as a tester.
From what I know I can say that both rear brake lights are connected together at thecolumn switch so when u step on the brake they both light. I determine that u have a flasher feed to thes circuit that doesn't belong. May be the brake feed and flasher from turn or hazard are crossed. Best way to shoot is to unhook all and start hooking back up oione system at a time and make it work before moving on. Good luck and let us know how it is going. Bob
Old 08-26-2009, 04:45 AM
Thanks to everyone for there help and the links. I believe the problem is that I missed a 12v wire connection. I'll let you know.
Turn signal switch KENMO Electrical 5 08-26-2008 04:01 PM
My Hiboy Needs Turn Signal System Higirl Hotrodding Basics 15 09-01-2006 01:19 PM
50 ford rear turn signal help Edbiosca Electrical 2 07-13-2006 07:45 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Turn signal flasher Seon Electrical 10 12-05-2003 10:34 AM
