turn signal issues
HELP!! we recently rewired our cj5 with an ez wire harness. great product, but we're having a problem with the turn signals and flashers. rear turn signals work fine in both directions, but both front flashers go on at the same time whenever the turn signals are engaged. we have already installed a new turn signal switch, so we're hoping someone out there can get us rewired properly.
Doc here,
Check to be sure your Turnsignal front wires didn't get swapped for the Park lamps OR hazard flasher at the flasher mount or switch. You need to Isolate left from right and can't Daisy chain then together in order for the Turn-signals to be effective. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Check and make sure you have a good ground for the front lights...sounds like a faulty electrical ground, and it could be getting an alternate ground, through the other element of the light bulbs ("feedback" of sorts). Cheers!
| Universal turn signal install | mbmopar | Electrical | 2 | 03-04-2006 09:26 AM |
| crazy right turn signal | fasteddiesage | Electrical | 6 | 02-07-2006 10:33 AM |
| turn signal blowing flasher fuse | RodFather | Electrical | 12 | 05-13-2005 06:23 PM |
| need turn signal switch & advice --help! : ) | WayOutCat | Electrical | 8 | 05-01-2003 10:56 PM |
| 1968 firebird turn signal | phoenix | Electrical | 6 | 08-07-2002 08:40 PM |
