Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Turn Signal Lights
Old 02-05-2013, 06:20 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
If the flashers don't work either, I'd start with, as memtioned, cleaning all the sockets, then make sure they have a good ground, then use a test light on the contact inside the socket to see if you're getting juice. If no juice at the socket, then inspect the wires to see if they are broken or frayed, then move to the column electrical connector to see if it's buggered up
