Turn Signal Lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2013, 10:33 PM
Turn Signal Lights
My Grandmas 1996 Buick Regal Gran Sport when you turn the left signal on it doesnt blink and neither does the lights outside Ive changed all the bulbs and still nothing could it be a wire or a switch in the column...
Old 02-04-2013, 03:41 AM
EOD Guy's Avatar
I'd start with the flasher, should be near the fuse box. Do your 4 way flashers work?
Old 02-04-2013, 11:26 PM
come to think of it no
Old 02-05-2013, 03:30 PM
Pantaz's Avatar
I had a similar problem with a '93 Caprice. I did all the usual troubleshooting, but everything checked out.
You know how they wipe dielectric grease on the bulb bases to prevent corrosion? Well, there was PLENTY of grease in the sockets, but it had become semi-hard and was preventing the bulb from seating fully against the contacts! (Removing and inserting bulbs would push the gunk around just enough for it to interfere.)
I was able to scrape out much of the crud with a small screwdriver, then about half a can of contact cleaner spray and various swabs to get the rest. Never had another problem with the lights.
The Following User Says Thank You to Pantaz For This Useful Post:
72Chevy_Shane (02-07-2013)
Old 02-05-2013, 06:20 PM
EOD Guy's Avatar
If the flashers don't work either, I'd start with, as memtioned, cleaning all the sockets, then make sure they have a good ground, then use a test light on the contact inside the socket to see if you're getting juice. If no juice at the socket, then inspect the wires to see if they are broken or frayed, then move to the column electrical connector to see if it's buggered up
Old 02-06-2013, 08:43 AM
I got it figured out...there was a bulb that didnt look like it shot but it was put a new one in and everything worked fine
Old 02-06-2013, 04:11 PM
EOD Guy's Avatar
Good to hear it was an easy fix
The Following User Says Thank You to EOD Guy For This Useful Post:
Old 02-06-2013, 10:44 PM
yea me to lol thanks for all that info for later on in case it aint a bulb so I know where to look
Turn Signal lights not working only when engine is running. JohnMercury Electrical 1 06-04-2012 06:11 AM
Driving Lights to Turn Signal Conversion 440man Electrical 21 01-17-2012 06:43 AM
Rear Turn Signal Not Working With Lights ON Craig legacy Electrical 1 09-02-2010 02:38 PM
Parking lights from Turn signal lights 32chevy vett Electrical 7 03-30-2007 06:46 AM
How to convert to flashing hedlights instead of turn signal lights!! willys36@aol.com Electrical 5 08-11-2004 07:16 PM
