Turn Signal lights not working only when engine is running. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2012, 09:14 PM
93 Mercury Topaz. The turn signal lights are not working when the engine is running. They work fine when I leave the keys in the ignition without the engine running. What could be wrong?
Old 06-04-2012, 07:11 AM
67Mustang Al.'s Avatar
Indicators
If you find the flasher unit and the +12 v hot wire feeding into it using a $6 light pen with a pointed end+ ( and a clip for the -ve end to chassis) turn the key to accessories and then start the engine with the 12v light probe still connected to the hot wire. If the light goes out you will need to follow that wire back to its power source by probing the wire with the sharp point of the light pen. Power should come from the fuse panel to the flasher unit with ignition on then travel to the indicator stalk to be switched left or right by the stalk. If the fuse blows you have a short , if it does not then you have a power drain with engine running. Check headlights for dim light. Alternator ok?? 14v approx.
Hope this gets you started.
Al.
Driving Lights to Turn Signal Conversion 440man Electrical 21 01-17-2012 07:43 AM
Taillights/turn signals/running lights Not Working PancakesandSausage Electrical 30 01-27-2011 05:02 AM
Rear Turn Signal Not Working With Lights ON Craig legacy Electrical 1 09-02-2010 03:38 PM
Parking lights from Turn signal lights 32chevy vett Electrical 7 03-30-2007 07:46 AM
How to convert to flashing hedlights instead of turn signal lights!! willys36@aol.com Electrical 5 08-11-2004 08:16 PM
