The solution to your problem is this; when the column was mounted for the first time someone neglected to install the steering wheel in the correct position. What you have to do first is, center the front wheels so that they are in a neutral position, disconnect the column from the idler shaft to the steering box, remove the steering wheel.
The Chevy column has a chisel mark at the steering wheel end of the shaft which matches to a mark on the steering wheel, there is also a flat area on the shaft without spindles, this corresponds to a similar one on the wheel, both these areas MUST BE ALIGNED to fit properly. Install the wheel on the column shaft as indicated above, and place the wheel in a neutral position (wheel spokes at 9 and 3 if two spoke, 10 and two and 6 if three spoke.). If there is a ignition lock on your column, lock it in place now.
Where the shaft exits the column, you should find a Double D shaft, if it is a chevy column. Move the universal joint on the idler shaft you disconnected earlier so that it connects up to the Double D shaft from the column. If the shaft is out of sync by more than a couple degrees, go to the bottom of the idler shaft where it connects to the steering rack, disconnect it. If the U-joint is a splined type, move it a couple of splines to get it to line up.
Go back into the car and check for steering wheel correctness, by moving the wheel left and right, and allowing it to go back 'to rest position". Re-tighten all your bolt work and take the car for a test drive. Try you signals, left and right, see how they cancel. Any further steering corrections will have to be done by moving the tie rods and should be done by a front-end alignment shop.
