sounds like you have an issue in the steering column, but try removing the right rear bulb and see if the front bulb will light up when you turn on the signals. then install the rear bulb and do the same for the front bulb as you just did for the rear. maybe it is just a socket problem or a bad bulb or the wrong bulb that only has one contact like a back up light(1156) when it should have 2 (1157) or if you replaced a socket maybe the wires got crossed during the switchover. if the bulbs don't light up ok try unplugging it below the column and test continuity for the lights from there out to the bulbs, or, if you have a jumper wire, connect the jumper wire to a power source at the fuse box (then if there is a problem from there out to the bulb it will just blow a fuse rather than melt a wire) then touch it to the wire for the right turn signals (you will need to know which wire that is before yu start so hopefully you have a wiring diagram). there should be 2 wires for the right turns, one is front right and the other is rear right and works along with the brake light circuit, since they both use the same bulb back there. just curious, do your brake lights work? did you replace the signal switch under the steering wheel? I have seen alot of poor quality signal switches before that will do exactly this problem. do the back up lights work? maybe the bulbs got switched up during the replacement scenario?
good luck, and remember, they are just signal lights. it ain't rocket science if you don't go thinking too much into it. do some quick checks for the right bulbs in the right places and proper grounds connected to the proper wires at the sockets. if that is all a go, remove the bulbs completely and turn on the signals-does the wiring still get hot? if it does then it could be a short in the steering column or the switch itself. check for the right kind of pigtails at the sockets to match the bulbs, ie-a signal/marker bulb has 2 contacts so it has to have a 2 wire pigtail. I have seen that messed up before, innocently enough done. check to see if the pigtail has turned in the socket and isn't touching the bulb contacts properly. check that the ground wire is connected to the wire that is the ground on the socket, it should be connected to touch the outside of the bulb. check for a pinched wire anywhere it goes through metal, like the firewall or in the trunk etc. it does sound like a switch issue though.
sorry for the scattered thoughts, it is early though and I haven't finished my coffee yet....
keep us posted
