Turn signal problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2005, 08:23 PM
SkintKnuckle's Avatar
Turn signal problem
I'm in need of a six volt turn signal flasher for a 1954 ford customline. I've had no luck getting one in my area. Can someone give me an address for this item.
Thanks very much
Old 08-22-2005, 05:19 PM
Wiki Edits: 31
Here ya go, theres lots to fit '54 Ford, If it's 2 prong it's the 3rd 1 down from the list. http://www.parts123.com/PartFrame.asp?ZTM=cadeffch&GHOME=www.macsautoparts .com/&TITLE=Mac's_Antique_Auto_Parts
Old 08-23-2005, 12:37 PM
Turn signal problem solved
Thanks for the web sites Matt1 67
I grew up in small town 5 miles from yours
Thanks Again
Old 08-23-2005, 04:32 PM
docvette's Avatar
Wiki Edits: 12
Flashers
Doc here,
I did a web search for 6 volt flashers last night for you..
It looks like (with the exception of stock VW's) Those are drying up! I found very few (at least on the INTERNET) offering 6 volter's..
SO , If you have an outlet for them there..it might behoove you to buy a handful of them for future fails...ya think?
Doc
Old 09-23-2005, 07:54 PM
54 ford signal light:
I can't find the flasher in my 54 Ford. Would you tell me where it's located?
turn signal blowing flasher fuse RodFather Electrical 12 05-13-2005 06:23 PM
Turn signal switch on column 49dream Suspension - Brakes - Steering 1 04-27-2005 08:00 PM
Changing out Turn signal switch on a Ford drewcoolness99 Electrical 10 07-02-2003 09:46 PM
Repairing turn signal switch Jag Daddy Electrical 0 06-17-2003 10:47 AM
turn signal and brake light problem PrimeMover Electrical 5 05-27-2003 06:26 PM
