What exactly are you working on?
Cole |
Car type? 1990 Chrysler LeBaron convertible. In '93 they switched to separates, though I'm under the impression that '90-'92 were identical, and '93-'95 had the change.
I can get a full copy of the wiring diagram of each, I just don't know where to start looking at it. |
This would be quite involved as everything from the turn signals and the brake light switch back will need to be re-worked. On the common filament system the brakes and the turn signals share the same wire from the steering column back. You be bet would probably get both diagrams. Go directly from the brake light switch to the brake light sockets. Then work on getting the directional lights working.
Artificial Intelligence is no match for Natural Stupidity Chet |
| flasher for turn signal | rick laplante | Electrical | 11 | 05-21-2009 10:41 AM |
| Turn signal problem. | two slow | Electrical | 3 | 03-04-2008 08:35 AM |
| Turn signal switch on column | 49dream | Suspension - Brakes - Steering | 1 | 04-27-2005 08:00 PM |
| turn signal canceling - after market wheel | cboy | Suspension - Brakes - Steering | 0 | 04-07-2004 07:34 AM |
| need turn signal switch & advice --help! : ) | WayOutCat | Electrical | 8 | 05-01-2003 10:56 PM |
