-   -   Turn Signal relay (http://www.hotrodders.com/forum/turn-signal-relay-235024.html)
DrBee 07-16-2013 04:20 PM
Turn Signal relay
I have a 1967 Cougar with turn signal problems. Does anybody know where the turn signal relay (flasher) is located ? Sequential cam works, emergency flasher works, but no turn indicators front or back and no dash lights. I replaced switch in steering column. Oh, and we checked the bulbs and fuses.
timothale 07-17-2013 06:42 AM
t bird parts.
The early cougars used T bird parts and those can have problems with moisture , relays, motors, what ever. later years use solid state parts, more reliable. you might find some info on a T bird Forum.
LATECH 07-17-2013 05:20 PM
I just saw a sequential setup, all new solid state, LED on TV. It was on Stacy Davids show- Gearz .
He had a setup for a 67 cougar called the interceptor.
Cant think of the vendor, but they are out there.
LATECH 07-17-2013 05:25 PM
http://www2.coucarpartscatalog.com/67w13a366.html
Actionjk 07-17-2013 08:28 PM
I remember working on a 68 Cougar with sequencial turnsignals at a Ford Mercury dealer in the early 70s,all I remember was in the trunk,right behind the rear seat back,was a whole panel of relays,flashers,and miles of wire,I know I fixed it,but it took a couple days!
timothale 07-18-2013 05:53 AM
new mustang sequential
I saw a new mustang the other day and it had sequential lights. I don't know if is factory or after market. I don't know what year cougars changed to solid state parts.
DrBee 07-18-2013 11:43 PM
Turn Signal relay
Thanx fellas. Mustangs Unlimited has the new electronic version that replaces the mechanical relays. Not going to fight it anymore. Just gonna bite the bullet.
