Turn Signal relay - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2013, 05:20 PM
Last journal entry: Gas cap next
Turn Signal relay
I have a 1967 Cougar with turn signal problems. Does anybody know where the turn signal relay (flasher) is located ? Sequential cam works, emergency flasher works, but no turn indicators front or back and no dash lights. I replaced switch in steering column. Oh, and we checked the bulbs and fuses.
Old 07-17-2013, 07:42 AM
Wiki Edits: 27
t bird parts.
The early cougars used T bird parts and those can have problems with moisture , relays, motors, what ever. later years use solid state parts, more reliable. you might find some info on a T bird Forum.
Old 07-17-2013, 06:20 PM
LATECH's Avatar
I just saw a sequential setup, all new solid state, LED on TV. It was on Stacy Davids show- Gearz .
He had a setup for a 67 cougar called the interceptor.
Cant think of the vendor, but they are out there.
Fact is stranger than Fiction
Old 07-17-2013, 06:25 PM
LATECH's Avatar
http://www2.coucarpartscatalog.com/67w13a366.html
Old 07-17-2013, 09:28 PM
I remember working on a 68 Cougar with sequencial turnsignals at a Ford Mercury dealer in the early 70s,all I remember was in the trunk,right behind the rear seat back,was a whole panel of relays,flashers,and miles of wire,I know I fixed it,but it took a couple days!
Old 07-18-2013, 06:53 AM
Wiki Edits: 27
new mustang sequential
I saw a new mustang the other day and it had sequential lights. I don't know if is factory or after market. I don't know what year cougars changed to solid state parts.
Old 07-19-2013, 12:43 AM
Turn Signal relay
Thanx fellas. Mustangs Unlimited has the new electronic version that replaces the mechanical relays. Not going to fight it anymore. Just gonna bite the bullet.
turn signal 72steve Electrical 1 04-16-2009 09:22 PM
turn signal ORHotrod Electrical 12 10-16-2008 11:14 AM
79 TA: hazard, right turn signal, brake signal out Gladis Electrical 6 12-25-2007 11:06 PM
Turn Signal jack76 Electrical 2 07-17-2007 06:45 AM
turn signal help!!please! LoudMalibu Electrical 10 06-24-2003 01:04 AM
