Well since my 96 caprice was crashed on the 13th of August I've been driving my 87 caprice. When I hit on the brakes the park lights come on. The dash and everything lights up. When I turn my left turn signal on my right signals come on too. Also when I hit on brakes that ding ding noise comes on like I left the lights on and took the key out the ignition. When my headlights are on that ding noise is constantly going and drives my crazy. Somebody help me
Sounds like you have some mighty big ground issues going on there, back-feeding into other circuits...Pull the dash and clean corrosion from all the connectors, and test all the grounds...
Go to the fuse box and look for blown fuses, I bet you'll find a few...
Clean the Steering column Plug and turn signal well of all dirt and corrosion.
You might also look for a single contact bulb 1156, in a double 1157 socket in the rear?
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
