Turn signal switch on column - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2005, 06:46 PM
My turn signal switch went bad and had to replace it on the 49 chevy.
It has a 1980's tilt wheel (just quessing) a 1986 chevy van turnsignal
switch was the same that I had. Anyhow when I took the steering wheel off they had a aftermarket hub on the steering shaft. This is were my streering wheel bolts to using 3 bolts and the middle nut that is on steering shaft.
I pulled this hub off. There is not a plate under it that has the spring that I have read about on the arcive post on steering columns I have the spring but not the plate. My turn signals never did cancel when you straighten out the wheel. My question is what cancels the signal. Is there something on that plate that does it.
Mark
Old 04-27-2005, 08:00 PM
milner's Avatar
the piece that you are probably missing is the cam assy. it goes on top of the spring and under the plate that you said is missing. you can buy wheel and horn adapters for chevy columns that let you us all the stock parts that you are missing. any performance or auto parts outlets can help you . good luck.
66 Impala turn signal switch assembly black66 Electrical 5 12-10-2010 05:07 PM
turn signal canceling - after market wheel cboy Suspension - Brakes - Steering 0 04-07-2004 07:34 AM
Changing out Turn signal switch on a Ford drewcoolness99 Electrical 10 07-02-2003 09:46 PM
Repairing turn signal switch Jag Daddy Electrical 0 06-17-2003 10:47 AM
need turn signal switch & advice --help! : ) WayOutCat Electrical 8 05-01-2003 10:56 PM
