I'm about finished with my wiring but just had something crop up. All of my lights worked just fine, but I had to pull my steering column to repaint it after scratching it pretty badly. Did the painting, reinstalled it, hooked it up electrically, now my park lights come on, front and rear. Brake lights work as designed, head lights, high and low, just fine, engine runs fine - but the parking lights come on as soon as I turn the master switch. I've run a full wire check, corrected a couple of wires that were hooked up opposite the correct way. I'm going to do one more, JIC I missed something....but
The column is an IDIDIT, which means the turn sign switch is a '70's GM (Camaro's look like they are the same as mine on the Rock Auto site). The connector says Delco Remy - so quality should be at least average. I recollect a good many years ago that many light wiring faults were due to a failed turn signal switch and am wondering if I have an early failure piece.
Any comment??
Dave W
Any comment??
Dave W
