turn signals - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2012, 08:56 AM
turn signals
I have a '51 Chevy Styleline and I need to add turn signals. I know I need to get the switch, but what changes do I need to make with the lamps/bulbs. The car has been 12 volt converted. Also, does anyone have any tips for fishing new wire to the back of the car. The previous owner installed a nice new interior and headliner and then bought a wiring harness upgrade. The dome lamp????? right in the middle of all that new work. My primary goal is wires to the back of the car and getting a fish line along the roof channel.
Thanks,
b720
Old 03-16-2012, 09:06 AM
you can buy a 4 wire set that is contained in a sheath, much like an extension cord only it is flat. sold by the foot. try a store that sells trailer stuff if nothing else. grote used to have it in their catalogue so napa should sell it. there is also one that is 4 wires bonded together but not in a sheath. it will have the 4 colors that are normally used for rear lights. not too sure how you will string the wire out without at least lifting the edge of the carpet. try to run the wire where you won't always be stepping on it, less chance of mechanical damage that way. be carefull putting the screws back in the threshold so you don't nick a wire (if that is where you are gonna run them.
Old 03-16-2012, 09:32 AM
Most cars run the turn/tail light wiring along a frame rail under the vehicle and to the rear lights. You can connect all the lights together (front and rear) in the engine compartment and then run a small bundle through the firewall to the switch.
Interior wiring usually runs from the dash under the door sill plate, and then up one of the pillars and into the roof to the dome light. Some vehicles are dual wall in the pillars and roof, so you can snake the wire through there and reach the dome light.
Bruce
Old 03-16-2012, 10:01 AM
Bruce
Yes,
Thanks. Actually the factory wiring is run along the roof line from the dash up the post at the windshield. A fish line gets lost along the way. I may resort to running the tail light wires along the frame. Let's see what others say.
Old 03-16-2012, 05:58 PM
Joe G's Avatar
I'm not sure how different a '51 is, but I recently added a factory accessory turn signal kit on a '52. If you can get a genuine GM switch from that era, that's the way to go because they are self cancelling. The GM turn signal switches had a wheel that rolled on the back of the steering wheel and controlled the cancelling mechanism. It's pretty slick, but only works with a stock column and steering wheel.
On this '52, the tail light harness ran along the left (driver's) side of the car at floor level, under the door sill plate. To add turn signals, I only had to run one additional wire to the back of the car. That wire became the left rear turn/stop. The existing brake light wire was used for the right rear turn/stop light.
The front park light sockets need to be changed to dual contacts so they can run dual filament lamps. Two wires need to be run from the turn signal switch to the front turn lamps. Also with the factory accessory turn signal kit, the fused power feed to the flasher screws right into the accessory power panel, so there is no need to cut or splice any wires anywhere.
As far as your dome light wire goes.....forget about it unless you want to redo the headliner. Maybe some of the upholstery experts on the forum will chime in, but I do not believe there is a way to remove and re-install the headliner on that car without ruining it.
Hope this helps.....
Old 03-16-2012, 06:19 PM
turn signals
That is very helpful Joe, Thanks. Are you from Whitehouse?
What Should I Do With These Turn Signals ? adantessr Hotrodders' Lounge 3 03-11-2011 12:30 AM
turn signals, Help! 39chevy Electrical 3 06-29-2008 01:29 AM
turn signals tweety Electrical 3 03-31-2007 03:13 PM
turn signals ksm Electrical 3 10-05-2004 03:36 PM
turn signals impala dreaming Electrical 5 02-24-2003 07:29 PM
