Get the special flasher and also replace the 1157 bulbs with the LED type.There is a way to make them work but it is better to have all LEDs.
One 1157 bulb will not draw enough amperage to operate the standard flasher, that is why when one bulb burns out the turn signal quits working. Either get a flasher made for LED's or replace the front 1157 bulbs with LED replacements.
Vince |
An electronic flasher will work fine for what you are needing (about 12-15 bucks)
If you go ALL leds then you will need to buy a much more expensive flasher made for a no load application. (either that or put some 194s up under the dash or something......the indicator lamps by themselves may be enough to trip the electronic flasher) |
| Turn Signals | 74redvette | Electrical | 15 | 10-14-2005 07:45 PM |
| Rapidly Blinking Turn Signals - It Was the Flasher | JohnTN | Electrical | 2 | 09-22-2005 02:26 AM |
| Turn signals won't shut off after turning! | 1meancuda | Electrical | 2 | 09-01-2004 01:48 PM |
| Turn signals, not flashing | 87442lover | Electrical | 11 | 08-13-2004 08:53 PM |
| HELP...LED Turn Signals... | Weimer | Electrical | 3 | 08-17-2003 03:01 AM |
