Turn signals only when work when motor is running. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2013, 02:06 AM
dasyhard's Avatar
Since I hooked up a custom light in my passenger dash board and dome light on my ceiling on my 56 chevy the turn signals does not work when the ignition is on. The custom light wire is connected to my ignition switch and my dome light wire is connected to the headlight switch. Everything else works in the lighting department, headlights, parking lights, brake lights and flashers. At first I thought the turn signals were not working at all because I checked the fuses and the bulbs. But when I drove the car at night and stopped behind another car and turned on the turn signal, I could see the reflection of the blinkers working in the back of the other car. So the blinkers does work but only when the motor is running. Additionally, the dash light turn signals in my phantom II gauges were operational before I hooked up the lights I mentioned. I checked under the dash but I could not see any wiring disengaged or fried. I even checked for wires not grounded properly. Can anyone point me in the right direction to analyze the source of my problem. Thanks in advance.
Old 06-12-2013, 04:57 AM
EOD Guy's Avatar
Not sure about about a 56, or if yours has been rewired...... I may be wrong but..........I don't think the blinkers are supossed to work with the ing in the off position. Head lights, stop lights and Haz flashers should work all the time reguardless of the key position.
Old 06-12-2013, 12:18 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
loose
Normally the turn signals are the only lights that are powered ignition ON.
I would guess that you have intermittent connection in the wire that feeds the turn signals. Replace the fuse just to rule that out. Also replace the flasher.
Electrically there is no difference between IGN. ON vs Engine RUN.
This assumes that the turn signals worked OK before the wiring adds.
vicrod
Old 06-12-2013, 05:30 PM
EOD Guy's Avatar
Sorry I just re-read your post.
Assuming they worked before your modifications. you have moved, disconnected something.
Remove the bulb to your dome light, see if that fixes it.
Then unhook the wire to your pass custom light, from the ing switch, see if that fixes it.
If they still don't work, check your steering column connector, I've attached several diagrams that might help you out
Name:	55 Gm steering column.jpg
ID:	74817   Click image for larger version
Name:	Early gm light sw.jpg
ID:	74818   Click image for larger version
Name:	Gm ing switch.jpg
ID:	74819   Click image for larger version
ID:	74820   Click image for larger version
Name:	Steering column connector GM.jpg
Old 06-29-2013, 02:11 PM
Its this is for a 64 chevy impala?
Old 06-29-2013, 02:18 PM
I just bought a new horn system for my 64 chevy impala, and dont know how to take out the old one and put the new one. I already took out the steering wheel, but now what????
Old 06-29-2013, 04:50 PM
Banned
dalyyico you need to read the post & not hijack someones post with your own . FYI this is a 56 chevy light question not a 64 impala horn question. dalyyico buy a factory manual for your car. also this makes it 3 post about your problem today. sorry to change your post dasyhard!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Can't get turn signals to work properly Pupsvette76 Electrical 7 04-27-2013 04:43 PM
Taillights/turn signals/running lights Not Working PancakesandSausage Electrical 30 01-27-2011 05:02 AM
LED turn signals don't work bentwings Electrical 2 04-26-2010 12:28 PM
why don't my turn signals work?? sexypizzaman Electrical 7 09-03-2008 06:02 PM
83 cutlass turn signals dont work Bpb196 Electrical 2 11-08-2006 08:02 AM
