Turn Signals Quit Working - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2010, 03:28 PM
10mikeymike's Avatar
I have a 37 Ford with a Kwik Wire 14 circuit wiring harness and a Flaming River tilt column. The other evening my turn signals quit working. I swapped out the old flasher with a new one and they worked for a minute and then stopped. I pulled out the new flasher and sprayed a little electric parts cleaner in the circuit board and replaced it. They worked again for a minute and then quit. I did this a couple of times and then realized that I could make them stop working by stepping on the brake. I did a search and found an old post from a guy with a Vette who was having an identical problem. In his case, there was a relay that was at fault. To my knowledge, there is no separate relay in my setup for the turn signals, only for the emergency flashers. All the bulbs are good and working properly. So are the emergency flashers. I've tried 2 new flashers with the same results.
Old 08-30-2010, 06:23 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Part the turn signal switch is the hazard flasher switch.
When the hazard flasher switch is NOT in use the contacts are closed thus enabling the turn signals operate.
Referring to the attached diagram see the closed "hazard" contacts that complete the circuit to the turn signals. Labeled on the diagram as "normal".
If these contacts are not making a good connection your turn signals won't work.
I know Flaming River is a good operation BUT things break>>>
vicrod
Old 08-30-2010, 06:25 PM
If you have a 3 pole flasher it wires in hot through the brake lite switch. There is a possibility that you break switch has a problem. If not check all bulb sockets turn signals can cause weird things to happen.
Old 08-30-2010, 06:59 PM
T-bucket23's Avatar
Wiki Edits: 26
If it is plugging into a board, there may be a crack or a cold solder joint. I would try turning the blinger on and push on the flasher and area where it plugs in to see if you can make it come and go. If you can you can look at the area where it plugs in for breaks or bad solder joints
Chet
Old 08-31-2010, 08:23 PM
Thanks to all for your responses. I found the problem. It waws a bad connection where the wire enters the back of the circuit board.
Turn Signals on Headlight Buckets ratfink35 Body - Exterior 1 04-17-2008 08:16 AM
'67 Tempest turn signals and tach q's 'Vid Electrical 0 10-09-2007 07:09 PM
Wiring For Turn Signals Seon Electrical 5 12-26-2005 12:04 AM
No turn signals. hogggster Electrical 1 04-15-2003 07:01 PM
turn signals impala dreaming Electrical 5 02-24-2003 06:29 PM
