Turn signals stay lit on dash? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2010, 06:36 PM
My buddy is rebuilding his dodge dart. His turn signal lights are staying lit up on his dash, everything works properly, brake lights, turn signals, etc. Is this a problem with the cluster????
Old 03-24-2010, 07:08 PM
poncho62's Avatar
Wiki Edits: 5
Usually, that means that there is a bulb burnt out, bad ground or something similar.....I take it those have been checked out.
When the arrows are lit are any of the bulbs lit?
Also, check the ground on the cluster itself
Old 03-25-2010, 07:13 AM
Thanks I will have my buddy take a second look today.
Old 03-25-2010, 10:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Another 'long shot' possibility is if the flashers are "ON", w/a bad flasher, or sometimes w/a turn signal or brake light switch also on simultaneously w/the flashers, can play tricks w/the indicator lights.
Old 03-25-2010, 05:24 PM
So he said that they come on when he turns on the running lights or the headlights???
Old 03-25-2010, 05:36 PM
poncho62's Avatar
Wiki Edits: 5
Bad ground somewhere, probably in the cluster....its grounding trough those bulbs
Old 03-26-2010, 07:43 AM
Thanks again I will pass on the info.
Old 03-26-2010, 06:18 PM
75gmck25's Avatar
I had that exact problem once when my instrument panel was not grounded under the dash, and once again when one front light assembly was not grounded (I left a ground screw a little loose).
Bruce
Old 03-26-2010, 06:47 PM
Does anyone know, maybe a dodge gu-ru, the instrument cluster on the dodge, does it have a ground screw?? On my dodge pickup the cluster has a center pin connection made up of 8 pins, I think, and the cluster is then srewed to the dash metal frame. There is no specific ground wire. Does the dash metal frame act as the ground??
Old 04-02-2010, 08:08 AM
Also check to make sure the right bulbs are installed or installed the correct way. I have seen 1156 bulbs in where 1157 should be and they feed back like that.
Old 04-03-2010, 10:38 AM
bobjob's Avatar
all of these answers sound like a good place to start.. if problem persists .... you might have a problem with your turn signal cancellation plate.. i've had to replace quite a few on older cars and school busses.. the contacts get worn out over time and little pieces of the contacts make a track for the current ..
1965 chevy impala turn signals impala dreaming Electrical 5 06-28-2010 08:04 PM
Prelude led turn signals yeepman2 Electrical 1 06-26-2007 08:53 PM
Help! Tail Lamps, but No Turn Signals or Brake Lamps 41willys Electrical 12 01-02-2006 08:11 AM
Adding turn signals to '53 Ford P/U first timer Electrical 4 12-04-2003 04:37 AM
Mach1 dash lights and turn signals SteveMach1 Electrical 6 11-21-2003 08:59 AM
