Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Turn signals won't shut off after turning!
Old 09-01-2004, 01:39 PM
flyfisher flyfisher is offline
suck, squeeze, bang, blow
Last journal entry: finally reeled it in
Sounds like the spring broke. Not a big deal. You have to remove the steering wheel. (if you have air bags, stop and check the air bag disable procedure). Use a steering wheel puller and when you get down to the signal light layer, you'll see the broken spring. just change it and put it all back together again. You can get a set of springs from a GM dealership.
