Turn your HF mini air saw into a sander - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-10-2012, 02:18 PM
Irelands child's Avatar
Glad you posted that - I was wondering if I should just throw mine away and suck up the $10.79(9.99+8% Albany Co. & NYS tax) Now, at least, another chance at 'life' for it.
As far as cutting steel - it stalls in anything heavier then tin can thickness
Dave W
Irelands child
  #17 (permalink)
Old 03-10-2012, 03:20 PM
"Glad you posted that - I was wondering if I should just throw mine away and suck up the $10.79(9.99+8% Albany Co. & NYS tax) Now, at least, another chance at 'life' for it."
IF you cut the front of the blade at an angle they work well for removing seam sealer/undercoat, think VW rear body panels. Cleaner, faster, cheaper than wire brush or Rolocs.
  #18 (permalink)
Old 03-17-2012, 01:13 PM
nine4gmc's Avatar
hacksaw blades are a good idea. this saw shines in fiberglass work, I also used it to cut fender vent holes in a honda civic fine, but you try cutting through any thicker metal and it bogs out.
  #19 (permalink)
Old 03-17-2012, 08:05 PM
evolvo's Avatar
Originally Posted by tech69
I just recently got an IR and it flies, but the thing is it's so fast it's hard to cut a dead on straight line. Do you find it easier to cut straighter lines with the hack saw blades installed. It seems like it would be but just checking. I think I'd be interested in hacksaw blades, especially some HSS ones.
My saw has a little straight blade brass screw down near the air inlet, you can use it to adjust the saw speed. If that doesn't work you can put one of these in your air line and reduce the air pressure to the tool.
http://www.google.com/aclk?sa=l&ai=C...+air+regulator
Use of my DA sander 38mike Body - Exterior 3 06-14-2010 08:05 AM
best DA sander to get? jss Garage - Tools 16 08-27-2009 06:09 PM
Need new sander oldred Body - Exterior 5 05-24-2006 07:12 PM
sander 5dogsisenuff Body - Exterior 14 07-02-2005 12:25 AM
Best sander for under 200.00? Pepsimayn Body - Exterior 13 12-02-2004 07:10 PM
