turning a 350 into a 383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2012, 01:18 PM
hi I need help guys I'm trying to make a 350 a 383 stroker but I dnt know were to start..its only goin to be on the street no drag racing or anything..I wanna know what all do I have to do from top to bottom and im not looking to spend alot of money but i know its not goin to be cheap either but i would like to go the cheapest but decent route and please be detail when you reply..if it helps any I'm in tampa bay area fl n its goin in a cutlass that's set up for a small block already with a grand national rearend b&m floor shifter that's for a 4sp trans so if you guys can help me out I would appreciate it sio much..
Old 05-22-2012, 01:40 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
This is one of the most common questions asked on here, type "383 stroker" into the search bar near the top of the page and start reading. Tons of information is available on this site. You just have to do some researching.
Old 05-22-2012, 02:32 PM
ok that's not as much as I thought it would cost..and what do I need the machine shop to do??
Old 05-22-2012, 03:01 PM
malc's Avatar
Living At The Speed Of Life
Would machine shop costs top the price of buying a ready to build 350/383 block from Summit ?$651.95 at the moment reduced to $629.95
Old 05-22-2012, 03:09 PM
malc's Avatar
Or a BluePrint Engines BP3830 - BluePrint Engines GM 383 C.I.D. Short Block Stroker
@ $2,095.00
Sift through this lot at Summit could be better than some of the machine shop nightmares Iīve read about.
Old 05-22-2012, 03:20 PM
ok yea I know that its diff kits I just saw a kit on ebay for almost 900 it was for a .030 which is the bored I was goin with now with that kit what work will I have to do to my block or what otha machine work will be needed??what else would I have to do after I buy the 383 kit that fits my build..
Old 05-22-2012, 03:25 PM
malc's Avatar
Iīd go for a long block then if I didīnt have the heads etc.
You also get a warranty.
BluePrint Engines GM 383 C.I.D. Stroker Base Budget Stomper Crate Engine with Cast Iron Heads $2,595.00.
Old 05-23-2012, 01:26 AM
well I'm willing to spend more than 1800 and I'm willing to buy what ever I have to so I can build a 383..I'm only lookin for about 400hp and I can get just about any part that I need for cheap..I can get any engine block that you guys tell me is the best to use because I seen some people sayin a 400 is better to build then a 383 so what do you think I should do just let me know and I would write everything down you tell me and start on my build and post pics of it as I go..I got access to a couple 400 blocks and a couple 350 block so which way should I go and if you know just about every part I need let me know and I will buy it and get started on the build..
Old 05-23-2012, 03:12 AM
malc's Avatar
Just how much experience do you have to build a motor ?
I ask because you need so much what do I need info before you start.
Old 05-23-2012, 03:24 AM
327NUT's Avatar
If you can get hold of a virgin (non-bored) 400 block then I would build a 406....which is a .030 over 400. A lot simpler to build for a new guy and a good running 406 will outrun a good running 383.
Old 05-23-2012, 06:36 AM
malc
well I never really messed with old skool cars I'm use to working on newer cars but I hear that old skool cars are easier to work on..and I know some of the parts I needed to start on the 383 I just don't know everything that's y I was asking what all will I need to make sure I'm not missing anything because I wanted to get everything rite the first time from the oil pan on up to the carb..
Old 05-23-2012, 06:49 AM
327nut
yea I can get 1 those easily its a guy that still has 1 running down the street from me out of the car already he was goin to take it apart and redo it but I can get it from him..so with building the 406 what parts do I change and what parts do I keep I know I keep a lot of the parts out of the 400 to make it a 406 so if you can run it down to me and tell me what all to get that will be cool..
350 or 383 Stroker? my350camaro84 Engine 19 07-30-2012 08:44 AM
350 vs 383 stroker 77stepside Engine 7 11-03-2008 08:49 PM
turning a 350 and 400 into a 383 and 377 bullheimer Engine 8 05-17-2003 05:43 AM
Turning my 350 into a 383? malibu65ss Engine 9 08-28-2002 12:56 PM
