turning down a flywheel on a lathe-thickness specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2013, 11:57 PM
does anyone know if i can cut down a flywheel 1/8". the total thickness of the flywheel is around 1 3/16".. my problem is that i am using a RAM hydraulic throwout bearing and need a setup gap of .150".. i am using a 1/4" spacer between the bellhousing and engine and want to shave the flywheel surface down 1/8 to get me in the set tolerance..
Old 04-10-2013, 12:29 AM
BOBCRMAN@aol.com's Avatar
Is that measurement at the outer area or the clutch disc surface area? Many f-wheels are relieved on the backside
Old 04-10-2013, 12:35 AM
clutch disc surface
Old 04-10-2013, 02:36 AM
blwn31's Avatar
If you can do it, I would grind it. My buddy has done several flywheels in his milling machine with a rotary table.
Keith
Old 04-10-2013, 02:51 AM
flywheel machining
I've done it several times. I leave an extra .005-.010 for the finish grind on a flywheel grinder. Trying to grind that much off the flywheel will be really dirty, take a long time, wear the stone too much & generally piss the guy off . machining the flywheel on the lathe leaves circular grooves, no matter how fine a feed is used. That is not good for clutch disc life. Blanchard ground is the preferred- acceptable way to do it.Good idea to check it for balance after it's all done, if it's a neutral balanced flywheel, balance the clutch on the flywheel , you will be glad you did it.
Old 04-10-2013, 06:20 AM
X2 and the stones for one of my machines are up to $600.00 a set.
Old 04-10-2013, 07:37 AM
THANKS TO ALL of you for the advice. this was holding me up for a couple of days.
Old 04-11-2013, 12:06 AM
Flywheel turning
Good luck with it . Let us know how it worked out for you.
Old 04-11-2013, 07:48 AM
MAJOR MISTAKE on my end.. i gave the flywheel to a friend to have cut down.. 1/8 was what i wanted but changed it to 3/32 .. i wrote 3/16 on the tag and 3/16 is what they cut off.. did i ruin this perfectly good flywhee.. damm im pissed.. this is what A.D.D.(attention defect disorder) does to me
Old 04-11-2013, 12:21 PM
flywheel
What engine was the flywheel from. I hope It wasn't something rare
Old 04-11-2013, 01:25 PM
nothing rare, i already went and got another flywheel from a parts dealer.. now i have to cut this one down.. all of this for a RAM hydraulic throwout bearing that is supposed to be for stock clutches.. bull****! don't work with my stock clutch
Old 04-11-2013, 01:59 PM
flywheel
Yea , typical "Hotrod " stuff. One change seems to mean 6 others to make it work. When I see the words " bolt on" I damn near gag or wanna throw up. I wish the industry in the whole would be more honest. But then , it probably means less $ in their pockets. BUT when it works (rare) how it's supposed to, it's your lucky day & you better run out & buy some lottery tickets. Hahahahah
Old 04-11-2013, 02:01 PM
flywheel
I forgot...."Ask me how I know".......I'll talk for hours HAhahah
Old 04-11-2013, 03:40 PM
i'm really worried now! i'm taking measurement after measurement to make sure that the springs on the disc don't hit the flywheel mounting bolts if i cut this one because that sure enough is what just happened when i took off too much on the other flywheel
Old 04-13-2013, 09:21 PM
bought a new flywheel, turned it down 3/32 and resurfaced .003.. added the spacer between engine and bellhousing and whalah, perfect gap.. thanks to all again who showed interest
Turning engine over without a harmonic balancer or flywheel? jason777 Hotrodding Basics 21 09-05-2011 10:22 PM
torque specs for my clutch and flywheel? John 1954 Transmission - Rearend 1 06-23-2007 11:43 PM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 08:20 PM
I got my lathe!! Speedlox Garage - Tools 6 09-07-2006 03:18 AM
Torque specs for a 75 455 pontiac flywheel 64_catalina Engine 2 06-28-2005 11:50 PM
