Turning engine over without a harmonic balancer or flywheel? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2011, 04:48 PM
jason777's Avatar
Last journal entry: Start Up
Hi, Guys.
I've got my engine together and I was planning on bolting the flywheel to the crank flange to gain the leverage I need to turn it over to top dead center so I can then measure my deck height. Unfortunately, the flywheel that came with the engine goes to a little 4 cylinder - LMAO. And I was planning on using the harmonic balancer off of my current engine for this one.
Does anybody have any tricks to turn it over some other way? The only solution I have is to use the rubber coated end of a hammer and press down on one piston.
Thanks.
Old 09-04-2011, 04:52 PM
Just buy yourself a crank socket for SBC (you'll need the woodruff key for the balancer).
You can get inexpensive ones for 15 bucks.
Old 09-04-2011, 04:55 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Here's whatr he is talking about. http://performanceparts.com/part/Moroso/61760 .
Cole
Old 09-04-2011, 05:31 PM
jason777's Avatar
Thanks, guys.
I can't get one locally. So, I may make one at work out of some stainless bar stock.
Old 09-04-2011, 05:33 PM
BOBCRMAN@aol.com's Avatar
If the crank has a keyway with a key in it. Use a large Cresent type wrench. Adjust to shaft size and the shaft will turn when you move the wrench, as the wrench cannot pass over the key. Been doin it for over 35 years..
Old 09-04-2011, 05:36 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
There is an actual flywheel device made for that Napa has them. It is a prybar with a hook device kinda like an old log peavy..you need one when installing tans as well to rotate the flywheel so the torque converter bolts line up in a convenient location..
In your case just putting the flywheel on temp may work for you..
Sam
Old 09-04-2011, 05:48 PM
You could use a 7/16-20 x 2-1/2" or so bolt(balancer bolt) and get a hex nut and washer to use like a jam nut. Screw the nut onto the bolt as far as it will go, put the washer on, then thread the bolt into the crank as far as it will go, then turn the nut CW until it bottoms on the crank like a jam nut.
As long as you have a long enough bolt that it will bottom out in the crank before the nut contacts it, you shouldn't have to worry about stripping the threads out of the crank.
FWIW
ssmonty
PS That is if your talking about a sbc.
Old 09-04-2011, 05:49 PM
Hey OMT some of these kids will have no idea what a log peavy is.
Old 09-04-2011, 05:59 PM
life is a temporary assignment
You need a fly wheel tool..
Old 09-04-2011, 07:31 PM
He said the flywheel he has won't work.. thus.. the turner won't work
Old 09-04-2011, 07:48 PM
Wiki Edits: 3
Well just dag nab it..shuckins..put a couple of bolts in the flywheel end of the crank and use a pry bar to turn it...
Sam
Old 09-04-2011, 08:26 PM
sqzbox's Avatar
My pipes are my music
I believe 40 yrs old is just passed the kid stage.
Old 09-04-2011, 09:46 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Back in the good ole' U P of MI we called them a cant hook. I never heard the word peavey until I moved to civilization. Not sure if that was a good thing or not. They say ignorance is bliss.
Old 09-04-2011, 10:54 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
This was going to be my suggestion as well.
It works well because you're not risking stripping the threads out of the crank snout and if the nut galls on the bolt you can still remove the bolt. Super simple.
Old 09-05-2011, 05:17 AM
This looks like the one I bought from Summit:
http://www.summitracing.com/parts/MIL-27000/
A little pricey but I wanted to play it safe. I stayed away from the cheap aluminum ones.
Yeah, I know there are other cheaper ways, but this worked great with a breaker bar.
jogasz28
Harmonic Balancer help sexypizzaman Engine 4 02-11-2008 05:21 PM
harmonic balancer chevynova Engine 4 06-15-2006 09:16 PM
engine vibration / harmonic balancer briansansone Engine 4 11-01-2004 10:29 PM
Harmonic balancer riesman20 Engine 7 06-06-2004 10:24 PM
Harmonic Balancer Ron Parr Engine 8 12-02-2002 04:10 AM
